Heater works for 10 mins then blows cold
Old Feb 4, 2013 | 07:31 PM
cadwiese's Avatar
Default Heater works for 10 mins then blows cold
my heater works in my civic but only for like 10 mins then it blow nothing but cold air...please dont tell me i need a heater core... :/
ty for the help.
Old Feb 4, 2013 | 08:03 PM
Emeraldbomber's Avatar
Default Re: heater help....
You need a new heater core. Just kidding!!! maybe......
Does your coolant gauge drop significantly at all after the 10 minutes?
Old Feb 4, 2013 | 08:24 PM
dirty19's Avatar
Ridin Dirty in Cali
dont be afraid if it is a core than needs replacement.
Its not terribly difficult to pull the dash and replace it.
I've done one myself recently.
Old Feb 5, 2013 | 06:25 AM
Former User's Avatar
Top off the radiator with coolant and then bleed the cooling system. Then go from there.
Old Feb 6, 2013 | 04:41 PM
cadwiese's Avatar
Default Re: Heater works for 10 mins then blows cold
no the coolant gauge doesnt move at all and i believe i have bleed the coolant and topped it off but i will check the levels also....
ty
Old Feb 6, 2013 | 04:43 PM
What car/engine do you have?
Old Feb 6, 2013 | 05:11 PM
N20keg's Avatar
Low coolant or u got and air pocket... probably
Old Feb 7, 2013 | 05:02 PM
cadwiese's Avatar
93 civic si hatch with a 95 b18 integra engine
Old Feb 8, 2013 | 11:51 AM
strategy400's Avatar
One thing about the heater cores, the pipes that go through the firewall are the softest crap metal available to man. If you try to pull/twist off those old crusty stuck on heater hoses with pliers you'll crush those ridiculously delicate pipes (one step up from tin foil) and possibly ruin the core for sure. I had to cut mine off with a sharp blade and replace them (good idea anyway).
2002hondaCivic
Honda Civic (2001 - 2005)
Apr 13, 2018 03:50 AM
SPOON_BeIgHtEeNsEe
Honda CR-V & Element
Nov 30, 2010 01:54 PM
R6E6I6D
Dec 21, 2005 02:01 PM
Jet Black
15
Dec 12, 2004 01:57 PM
simplypinoyy
23
Aug 6, 2004 03:06 PM
