EK wont start, HELP!!
I have a 97 honda civic coupe with a 99 gsr swap. Up until recently the car worked fine but the other day when I tried to start it nothing happened. The accesories wont even work. I tried jumping it and swapping out the battery as well. I also changed the battery terminals because they looked old and I checked the fuses and grounds and everything checked out good. Anyone know what can possibly be the problem? Everything I find is on cars that will crank but wont turn over. This has the symptoms of a dead battery but its not. I did lock the keys in the car and they were stuck in the ignition for a while. Would that have ruined something?
sounds like your main fuse is blown. when your main fuse is blown its same thing is a dead battery check up 40 amp main fuse if u haven't
unless you have done any type of wire work or short out the car by touching some thing then all i can think of is your 40 amp fuse.
yea it can do u have a volt meter if u do then put a good battery in go to fuse box main fuse an see if u get 12 volts on one side
an if u do try on other side an if u dont then bam bad fuse it might look like its not bad
can be but also try get two wires an an 30 amp fuse under dash fuse an wire one side of fuse an then screw it in where main is then the other wire on other side of fuse to other screw an try turning the key on if u got power then bam u kno bad fuse
hope this helps an also clean ur contact points if u need more help ill do my best to give ideas to get it fixed
#1 Dominican
Dec 27, 2008 12:50 PM
DACteg
May 15, 2007 06:35 PM
speedrcr24
Oct 9, 2006 05:14 AM
