Car still sounds sluggish, why?
Old Feb 3, 2013 | 12:59 PM
jonyi27's Avatar
Default Car still sounds sluggish, why?
So my car been sounding like it runs sluggish, I change spark plugs in November, and just put new exhaust manifold Gasket the other day, what else can it be? I hate the sound I can hear it a lot in 5th gear going 60mph and then press on the gas, any help will be appreciated!
Old Feb 3, 2013 | 01:03 PM
oakteg21's Avatar
Default Re: Car still sounds sluggish, why?
Need more info thats to general to help out with. Try giving vehicle mileage maybe mods you have done to your car inform us more so we can help you.
Old Feb 3, 2013 | 01:13 PM
jonyi27's Avatar
B20z 96k miles I/E/H that's about it
Old Feb 3, 2013 | 03:07 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car is also makes things easier.
When was the last time the fuel filter was changed, [how many miles/months]?
Have you checked fuel pressure? 94
Old Feb 3, 2013 | 04:13 PM
jonyi27's Avatar
94 integra, with 2000 crv b20 engine with 96k miles, and I changed fuel filter end of November 2012
Old Feb 3, 2013 | 04:14 PM
jonyi27's Avatar
How do I check fuel pressure
Old Feb 3, 2013 | 07:39 PM
GagnarTheUnruly's Avatar
Fuel pressure gauge. Search.
Could be a lot of problems that cause poor performance. Fuel, ignition, airflow.
Gotta check timing too.
We need more info or we won't be able to do much to help.
Old Feb 3, 2013 | 08:40 PM
jonyi27's Avatar
How much would a shop ask for to check timing?
Basically all info is up top
only new thing is spark plug & fuel filter installed in Nov..
Old Feb 4, 2013 | 06:49 AM
oakteg21's Avatar
Uggi
Every shop charges different so check with a couple and see what they say....there many things that can b causing that timing, bad o2 sensor, somesort of vacuum leak, pcv valve, there are more things that can cause it someone just needs to take a look at it. Unless you can complete describe your build from start to finish then describe when those it feel sluggish? What are conditions when this occurs?(uphill, downhill, acceleration, deceleration, etc.) How do you know it feels sluggish? If you can answer all these questions then maybe we could be able to help but your better off taking to your local mechanic to take a look at it.
Old Feb 4, 2013 | 08:26 AM
Just get a mechanic to look at it. There are a lot of things to check and if you are considering paying someone just to check timing you might as well have them diagnose your problem.
76 camaro car
Mar 15, 2016 05:54 PM
eternaltech
Nov 5, 2012 09:07 PM
slowwcivic
Dec 1, 2011 11:50 AM
slikz714
Feb 26, 2010 11:37 AM
Lonny
Apr 13, 2003 01:12 PM
