do you need tack gasket sealnet for a d15 valve cover gastket?
Old Feb 2, 2013 | 10:44 PM
sorwdfish's Avatar
Icon2 do you need tack gasket sealnet for a d15 valve cover gastket?
ive seen videos on how to do it but there never use tack sealant?
Old Feb 3, 2013 | 12:25 AM
250r king's Avatar
Default Re: do you need tack gasket sealnet for a d15 valve cover gastket?
Yes factory use silicone I use some copper silicone from auto store put where gasket meets cam caps both side of caps I even put between the gasket and valve cover . Make sure to use some brake cleaner on a rag to clean off any oil that is there . Also Dont glob it on. Use pea size drops .
Old Feb 3, 2013 | 06:48 AM
EfyourK's Avatar
Friend has an ALL data subscription an it only recommends using silicone on the valve cover gasket if you plan on re-using your old one to help with possible seeping that can appear
Old Feb 3, 2013 | 08:42 AM
RuneRavenX's Avatar
I say use it anyway. It ensures a good seal.
Shaguar47
May 28, 2007 08:47 AM
porter
Feb 16, 2007 01:46 PM
budget
Feb 16, 2007 01:22 PM
type Gendy
10
Sep 6, 2003 10:44 AM
E-spec Tuner
Apr 17, 2003 09:16 AM
