Strange wiring
Old Feb 2, 2013 | 05:47 PM
Telecatster's Avatar
Default Strange wiring
1998 Honda Civic EX. I purchased it 8 months ago. The previous owner (who I can' get in contact with) installed an Alpine ida x200 head unit. He wired in a switch near the cruise control and if it set on the up position the head unit will stay on when the car is off. In the down position the head unit will shut off normally when the car is turn off. In the down position 3 small LED lights will blink *car has fake security alarm* and in the up position they turn off.
When the switch is in the down position the FOB will not work correctly. Also, the drivers side window occasionally will not work until I manipulate the window switch on the driver's side door.
Any suggestions?
Old Feb 3, 2013 | 02:38 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Strange wiring
Er. Return the wiring to stock. Have you actually got under he dash to inspect anything?
Old Feb 3, 2013 | 03:34 AM
I forgot to mention that all worked well until 3 weeks ago. I haven't adjusted any wiring to this point. I unhooked the negative side of battery about 3 weeks ago when I replaced the dizz cap. I reset the ECU by following directions I found on a few sites. Coincidence? I don't know, I tried resetting the door lock/FOB using posted directions and that didn't fix it.
There are a couple wires cut and tape near the head unit, but I have not inspected closely near the switch at this point. I am trying to figure out what the previous owner was trying to achieve by installing the switch. My guess is that it was the only way to get the "security" LED's to engage while turning the radio off. I am going to try to reset the locks again while the switch is in the UP position. I haven't tried that yet, if it doesn't work then I'll look closer into the wiring.
Old Feb 3, 2013 | 03:44 AM
The Grumpiest
Unless you're trying to keep his fake LED setup, remove all trace of it. Then check for a shorted wire somewhere.
Old Feb 5, 2013 | 12:31 PM
It's looking more like the window switch contact is the issue
Blaz1541
Jun 27, 2016 03:30 PM
slowcivic2k
Oct 11, 2007 06:47 PM
DC4_MADMAN
Jul 16, 2005 02:36 PM
Maddhatcher
May 28, 2003 12:22 PM
