91 dx sedan out of fuel at half tank
Old Feb 2, 2013 | 03:07 PM
Dnizzle's Avatar
Default 91 dx sedan out of fuel at half tank
My ef is out of gas at half a tank. It only takes 5-6 gallons to refill to full as it spits out of I try and pump more in it.
Old Feb 2, 2013 | 03:23 PM
EfyourK's Avatar
Default Re: 91 dx sedan out of fuel at half tank
https://honda-tech.com/forums/performance-45/fuel-tank-kit-fcs-fab-ready-install-eg-ek-dc-ef-2639341/
All I could find with my friend "Search"
Old Feb 2, 2013 | 03:26 PM
EfyourK's Avatar
Because race car
Old Feb 2, 2013 | 04:15 PM
pimpwagon's Avatar
drop the tank, then reattach the pickup hose and sock to the fuel pump.
Old Feb 2, 2013 | 04:27 PM
grog's Avatar
Have you looked at the tank? is it dented?
There's a 2 way valve that relieves the pressure from the tank as it is filled. I suppose that could be your issue but I have no experience with this. I believe this runs to the charcoal canister under the hood.
Edit: I think Pimpwagon may have nailed it.
Old Feb 3, 2013 | 10:50 AM
Dnizzle's Avatar
This is what I was thinkin. Always good to get others opinions in my experiences.
Old Feb 3, 2013 | 11:23 AM
pimpwagon's Avatar
There's a possibility you don't have to drop the tank. On certain EF's You can remove the back seat and access it from the top. On my 91 hatchy I had to drop the tank. I have no idea about sedans.
Old Feb 3, 2013 | 11:51 AM
Tims Toy 500's Avatar
A friend had the same thing happen to his very old jeep. We dropped the tank and found it was 1/2 filled with water. The o-ring on the sending unit had rotted so badly that it was just rattling around in the hole. I suspect that's where (over time) rain had seeped in.
Hope that helps.
Best of luck!
Old Feb 3, 2013 | 11:59 AM
grog's Avatar
While i did a search on this subject I found a thread discussing this question. Some VW owner though, it ended up being a dummy half gas tank used for smuggling, the repair shop found that half of the tank was walled off and packed with cash.
Old Feb 3, 2013 | 12:15 PM
pimpwagon's Avatar
I hope that's your problem. I also hope the bills aren't marked or sequentially numbered. LOL
Old Feb 10, 2013 | 06:09 PM
Dnizzle's Avatar
That would have been nice. Dropped tank replaced rubber hose sock was there same problem. Replaced pump. Problem solved. New one to me.
Old Feb 10, 2013 | 07:40 PM
pimpwagon's Avatar
F--k it. now you won't have to worry about a failing pump for another decade. LOL
BIGef
Sep 10, 2013 03:02 AM
91cb7h23
Feb 10, 2013 04:13 PM
jdmeg6118
Sep 30, 2012 12:57 AM
FO SHO
Apr 11, 2010 01:30 PM
red civic standard
May 17, 2004 10:54 AM
