civic 95 ex fills up with 3 gallons, HELP!
Old Feb 2, 2013 | 02:09 PM
Redis_323's Avatar
Icon2 civic 95 ex fills up with 3 gallons, HELP!
Hey all. I have a civic 95 ex coupe and i have to constantly be putting gas because it only takes 3 gallons max. Since I purchased it, its been this way. the fuel gauge is at full after i fill it up but as soon as its empty it goes down half way. i know my gauge is acting up and i will fix this but what i don't understand is the tank issue only taking up 3 gallons. any help is greatly appreciated, thanks
Old Feb 2, 2013 | 02:21 PM
cetcivic's Avatar
no one wants to hear the truth
Default Re: civic 95 ex fills up with 3 gallons, HELP!
3 gallon race tank?
Old Feb 2, 2013 | 02:45 PM
hahagasdcrx's Avatar
The extra kilos of coke in there take up the other 9 gallons! The float in your fuel tank may not be functioning properly or sending unit bad. Search for the way to test the output and see if it is withing specs.
Old Feb 2, 2013 | 03:10 PM
grumblemarc's Avatar
The Grumpiest
Wait. You mean PHYSICALLY you can only put 3 gallons into the tank? Don't see how that's possible if that's the case.
Old Feb 2, 2013 | 03:57 PM
Redis_323's Avatar
YES, the car only takes 3 gallons of gas in the tank. Its really just annoying now because I literally have to be at the gas station daily putting in $10 max because it can over flow. anyone know what I should do?
Old Feb 2, 2013 | 04:41 PM
nub's Avatar
nub
The kilo remark above may not be far fetched.
Old Feb 2, 2013 | 04:42 PM
nicks96's Avatar
Possible float malfuction. does the gas pump click off at three gallons or do u stop it yourself?
Old Feb 2, 2013 | 04:53 PM
Redis_323's Avatar
what do you mean? im sorry, im just not great with cars.
Old Feb 2, 2013 | 04:56 PM
Redis_323's Avatar
yes the gas pump clicks off, so i tried putting in a bit more to see exactly how much can go in and it over flowed at 3 gallons. once those 3 gallons are up the car starts loosing power and really feels like its about to turn off, which leads me to believe its almost empty and the fuel gauge is at mid way.
Old Feb 2, 2013 | 04:57 PM
nub's Avatar
nub
I'm saying your car may have been a mule at some point considering your location. Hidden compartment-drugs.
Old Feb 2, 2013 | 05:23 PM
Redis_323's Avatar
lol. it might be possible since the car was not operated for 3 years till i got it. is there any way i can check this? if so what can i do?
Old Feb 2, 2013 | 05:26 PM
nub's Avatar
nub
I'm calling halvsies for info.
Old Feb 2, 2013 | 05:40 PM
nicks96's Avatar
DRill a hole in bottom of tank and see what and how much comes out
Old Feb 2, 2013 | 06:08 PM
Redis_323's Avatar
?? u mean youd like to know as well?
Old Feb 2, 2013 | 06:09 PM
Redis_323's Avatar
ok i have no problem with that, but what do i do after to cover it up?
Old Feb 2, 2013 | 06:14 PM
jbpnoman's Avatar
...Don't drill a hole in your gas tank. Can we stop the idiocy?
OP, fill up at the closest gas station to your house. Drive home, remove your rear seat and pull out the fuel pump assembly. Use a flashlight and see how much fuel is actually in there.
Old Feb 2, 2013 | 06:30 PM
Redis_323's Avatar
lol. ill do this and see what happens.
Old Feb 2, 2013 | 06:31 PM
owneyboy's Avatar
not sure if you know what welds look like?
1, (google) how to change fuel pump. and follow those instructions it will help you identify where and what your gas tank is and doing that you can inspect it. under rear seat..
2. there is a 17mm fuel drain plug under your car ALREADY do not need to drill holes while under car look and see if the gas tank looks factory.
3. was your car ever a "race/drag" car maybe has an altered external/internal fuel cell instead of factory 12 gallon tank.
4. your car was really a mule and was altered for the use of transporting drugs over border and only needed 3 gallons to do so.
Old Feb 2, 2013 | 06:51 PM
Redis_323's Avatar
yeah i just looked up the info and seems pretty easy. I honestly dont know if it was ever raced for sure..... i sure hope not since its very inconvenient for me right now to be pumping gas quite often.
Old Feb 2, 2013 | 06:52 PM
nub's Avatar
nub
/\/\/\ This.
I still have dibs.
Old Feb 2, 2013 | 07:37 PM
eghatch9295's Avatar
Stancetard Hate Monger
ill pass on gas soaked coke. in for the results.
Old Feb 2, 2013 | 09:43 PM
pelayo114's Avatar
I'm in for the results as well. Got me really curious now.
Old Feb 2, 2013 | 10:01 PM
Xenon7's Avatar
O_O LOL WHAT. Gotta see this. Please do this ASAP.
Old Feb 3, 2013 | 06:51 AM
Former User's Avatar
^Your gas gauge isn't working.
So when the gauge reads "empty", there's probably still 9.5 gallons left in the tank.
Old Feb 3, 2013 | 06:53 AM
There is a hose that is above the pump itself before it comes out the top. If the hose is cracked or a clamp is loose, the line would suck in air if the fuel is below that line in the tank. May want to pull the pump and check that connection and hose.
