b16 rebuild questions
Old Feb 2, 2013 | 11:23 AM
Xathine's Avatar
Default b16 rebuild questions
I have a few questions concerning my upcoming rebuild. I tend to get a little carried away.
Is it safe to reuse mains / bolts?
Is it safe to reuse rod bolts when reusing stock rods?
The reason i ask, my last rebuild i was talked into picking up arp rod bolts with arp mains. With that came a line hone and rod reshape. It was quite expensive considering it was just an OEM refresh.
More info: will be in a DD with a stock 16g greddy kit 250-275whp. Zero intentions of picking up pistons /rods.
Old Feb 2, 2013 | 11:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 rebuild questions
Pardon me for saying but that sounds absolutely nonsensical to not go with something like a Vitara, Weisco, etc. setup if you plan on rebuilding the bottom end anyways. Chaeper than getting a line hone and rod reshape. Don't understand the logic in this at all.
Old Feb 2, 2013 | 11:33 AM
Xathine's Avatar
Appreciate you pointing out my failed logic. It was something i was completely unaware of.
Back to topic. Safe to re-use the stock rod bolts and main bolts?
Old Feb 2, 2013 | 11:41 AM
The Grumpiest
Don't see why not since stock B-series internals can handle that power easily. That would include the rod bolts. No one one ever replaces mains. Never seen it. Who wants to bother with a line hone when not needed?
Waste of an opportunity.
Old Feb 2, 2013 | 11:49 AM
Xathine's Avatar
My exact thoughts after my last build. Thank you very much!
DefiantGSR
Oct 25, 2008 11:07 AM
itr_henrik
14
May 25, 2007 02:08 AM
Wazup
Mar 31, 2005 02:58 PM
b16supertuner
Dec 15, 2003 05:21 AM
turbociv
Sep 8, 2003 05:41 AM
