High compression pistons and gas.
Idk if I'd chance it on a b20 block, slightest detonation & you got a cracked sleeve just be super careful have you looked into e85? I thought about running my 13.1 on pump, but why have such high compression and not able to utilize it %100
Realistically, you can runany C/R you want with any fuel you want, its all about the tune.
I COULD run 15:1 on 87 octane, but it would have so much timing pulled that it wouldnt make any power.
Boosted guys have an effective C/R of beyond 15:1 in boost, and they run on 91 octane. But with boost, you dont need timing to make power, the turbo takes care of making power.
On an NA motor, you need timing to make power, so the higher the C/R and the lower the quality the fuel is, you have to pull more timing out to avoid detonation, thus, making less power.
You could potentially make more power on a 11.5:1 motor on 91 oct. than on a 13:1 motor on 91 oct. simply because of the tune, the lower compression motor gets more timing and is more aggressivley tuned, so it make more power, make sense?
This is why it is important understand the limits of the fuel you plan to use in your area (depending upon use of the car) when planning your build.
elmisias
Jan 25, 2010 04:54 AM
otacon122
Oct 29, 2008 02:32 PM
