headgasket oil leak? Oil leak near edge of block, Pictures inside.
Old Jan 31, 2013 | 08:33 PM
93grayeg's Avatar
Icon2 headgasket oil leak? Oil leak near edge of block, Pictures inside.
Car has a slight oil leak, It's not a lot but coming from what look's to be the head gasket, The car has a new cam seal, and valve cover gasket so I know it is neither of those, After the car is driven it is wet in the same area every time, The car has no signs of a bad head gasket, no overheating , smoke, or anything abnormal and the car runs just fine, Motor is a darton sleeved gsr , car has a golden eagle head gasket. Any idea's where else this leak could be coming from? I really cant see any signs of how oil is getting here besides the head gasket. Thanks guy's
Old Jan 31, 2013 | 10:48 PM
viper_boy403's Avatar
Default Re: headgasket oil leak? Oil leak near edge of block, Pictures inside.
looks exactly like when my D15 headgasket was leaking oil from that exact same spot :/
Old Jan 31, 2013 | 11:27 PM
4tika4's Avatar
if you wipe the front of the block off how long is it before its wet again?
Old Feb 1, 2013 | 12:01 AM
Nisif's Avatar
From the pics it looks like the headgasket. Might as well check the vtec solenoid gasket and the dizzy seal since it's in the area and you didn't mention it.
Old Feb 1, 2013 | 06:14 AM
SiRCiviC94's Avatar
Don't worry about it. Minor leakag the dizzy oring or solenoid usually, mines been like this over half a decade of racing nitrous turbo and abuse. It's not the hg
Old Feb 1, 2013 | 07:57 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Don't worry about? Don't pawn your car care tactics to someone else guy. Check the distributor for leaks, I doubt it's the cam seal but maybe it is. Did you hondabond or rtv when you replaced the seals?
Old Feb 1, 2013 | 08:07 AM
turbohatch96y7's Avatar
Dizzy o ring, vtec solenoid seals or cam seal. NOT the head gasket.
Old Feb 1, 2013 | 08:44 AM
93grayeg's Avatar
the cam seal was replaced from owner before me, which looks to be a golden eagle cam seal. Thanks for the reply. I used hondabond on the Valve cover gasket on the edges where it recommends.
Thank you, I did not think about any of those, It just seems like it is dry in the area of the cam seal , and vtec solenoid...unless it is leaking behind and coming down the backside.
Old Feb 1, 2013 | 09:37 AM
Take the cam seal out and put new o rings. Honda bond your vtec solenoid seals and put a new dizzy o ring.
If its still leaking could be the valve cover gasket. Good luck
Old Feb 1, 2013 | 09:42 AM
93grayeg's Avatar
Ill do all that and report back, So no need to worry about a possible head gasket issue?
Old Feb 1, 2013 | 09:55 AM
Muckman's Avatar
Moderator in Chief
Seepage from that corner is common.
I’ve had it occur on 4 built engines all with milled blocks/heads.
I’ve tried different MLS head gaskets and copper spray.
The only thing that worked was a thin ring of RTV around the oil ports in that corner.
It makes absolutely no sense that a head gasket can contain thousands of PSI but not return oil under no pressure.
Old Feb 1, 2013 | 09:59 AM
magic carpet's Avatar
Old Feb 1, 2013 | 12:45 PM
93grayeg's Avatar
I heard this is a common issue , so pretty much no way to stop the leak without removing the head? If thats the case ill deal with it.
Old Sep 22, 2018 | 09:49 PM
yuki_civic's Avatar
5 Year Member
Dunno if you found your answer yet, but the b18c1 takes 4.2 quarts per the haynes manual. Hope it helps
Old Sep 24, 2018 | 03:46 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
odd that you drug up this old topic, Ive got a oil leak it the exact same spot and was trying to figure it out
2kdrift
May 18, 2013 12:00 PM
clys
14
Apr 21, 2011 04:04 PM
dc2_dude
Feb 13, 2009 12:12 AM
jakscivic
May 2, 2006 02:26 PM
PatrickGSR94
Mar 5, 2003 10:02 PM
