IACV advice
Old Jan 31, 2013 | 08:28 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default IACV advice
i am at a crossroad. i am using CBR ITBs and i need to make a decision on whether to keep the valve, or to eliminate it. i can disable it in Neptune.
how much drivability is lost with it gone?
Old Jan 31, 2013 | 08:34 PM
doood's Avatar
been there done that
Default Re: IACV advice
i know a few guys without one and it's honestly not that bad. i'm thinking about doing it too just to avoid cleaning the damn thing.
Old Jan 31, 2013 | 08:37 PM
the issue is, i can't simply disable it now and then add it on later, i am making the vacuum log and i either make the provisions for it now (PITA) or forget about it altogether.
Old Jan 31, 2013 | 08:48 PM
doood's Avatar
cant make a fitting and plug it for future use?
i assume you'll be tuning using alpha-N and not the map? how often do you drive the crx? if it's just a weekend warrior i wouldnt even think twice and delete it.
Old Jan 31, 2013 | 08:56 PM
i haven't driven it in months. i plan on driving it daily. and as far as fabrication goes, i would need to make a plate that accommodates the valve, with its appropriate air routing.
Old Jan 31, 2013 | 09:01 PM
since it will be a boosted car, i will have to use a blend of alpha-n and MAP tuning.
EG6_LS_BOOST
Apr 5, 2013 09:25 AM
blackeg
Apr 26, 2007 06:33 PM
stealth civic
Mar 21, 2004 01:22 AM
speedsightsound
Feb 8, 2004 07:36 PM
Want2race
Jan 14, 2003 02:07 PM
