SEARCHED: Need a 4x114 hub assembly
I have been searching ALOT on this as my Integra is not passing safety inspection due to the rear driver side hub assembly.
Searching comes up with a lot of talk, but zero defined answer. Does ANY one know of a company who sells a compatible replacement? Sorry if I am acting like a noob. I want this damn car on the road! I have spent over $2k restoring it, after the $3k price tag.
Found a replacement company, but they are overseas and it's +$400 for a complete set. Needless to say, I was not expecting to spend that much.
Any help is appreciated.
EDIT: this is not a WTB thread. I plan on making one of those in the classified section soon.
Originally Posted by cvcrcr99
Found this thread.
https://honda-tech.com/forums/suspension-brakes-54/4x114-3-conversion-parts-list-brake-tech-thread-2090223/
Can anyone confirm that this is correct?\/
Yesterday I pressed the old bearing out, new one in, then pressed hub in. Re-assembled sus and everything is golden. Thanks again to Jeff (Kiwi), his crew chief, and everyone else that has posted info about the 4x114 Integra setup. To recap the parts you need for hub/bearing replacement:
hub is 44610-S10-000 without studs
or 44600-S10-000 with studs
bearing is 44300-S04-A02
Again, this is for the REAR
ok, Found a thread saying 98-02 Accord (rear drum) hub assemblies work with little modification. Has ANYONE tried this? The OP who posted all of this information about 3-4 months ago didn't reply to my PM asking if he is still using them or not.
I need to search and test some of this stuff as well. I had read that the part was discontinued?
I do have a bnib Accord 98-02 4 cyl EX hub from my previous Accord still. I should measure that as well.
^^ Thanks man. Did the EX Accord hub come from a car with rear drums, or discs? I know nothing about Accords, just assuming that the EX's came with rear discs and other trims like the LX came with drums. I really wanna keep the OEM ITR 4x114 wheels I have. I think they look great.
I PM'd the person who made the thread about it, but he has signed on and posted since then, just ignored my PM. Ugh. Just wanna ask if he is still using the Accord hubs or not.
If anyone else has this problem, I was able to use 4x114 rear hubs from a 1998 Accord. Refer to Post #27 on the below linked thread:
https://honda-tech.com/forums/showth...3082998&page=2
Props to Russ^^ for helping out and doing a **** ton of research.
chameleon
Nov 12, 2002 04:37 PM
