91 ef hatchy help
so yesterday i got this hatch it turned on drove it and the check engine light turned on so i got home parked the car and the car wouldnt start so we tried jump starting it and it started so today in the morning i got up and tried to start it and nothing tried jump starting it and nothing again what can it be ?
i was told to check ignition switch and nothing it had a relay mikey rigged to it but 2 other wires werent connected to anything so i bought a new switch and installed and nothing so my friend says there has to be a light on on the ecu and i get no light when i turn the key
Need more details. What is it doing? Turning over and not starting or nothing when you turn the key? If the cel came on you should be able to turn the switch on and watch the flashes on the ecu led (assuming the switch is sending power to the ecu).
Posted from Honda-tech.com App for Android
no none of gas or fuel ligts came on i got a new ignition shitch nd when i took out the old one it had a relay switch rigged to it dont know if i need to re wire it to the new switch
aquito
12
Jun 17, 2009 05:26 PM
slow hatch
Apr 19, 2004 10:00 AM
