98 civic with multiple codes please help!!!
Old Jan 30, 2013 | 04:06 PM
98exb16's Avatar
Icon2 98 civic with multiple codes please help!!!
98 civic ex with 99 si motor bought the car as is just got it running again hooked up my scanner and have multiple codes not sure where to begin the car spits and sputters when you first start it and has a slight misfire once its up to temp here are the codes
1. P0108 manifold absolute pressure or barometric pressure circuit high input
2. P0113 intake air temperature sensor 1 circuit high input
3. P0117 engine coolant temperature sensor 1 circuit low input
4. P0118 engine coolant temperature sensor circuit high voltage
5. P0122 throttle/pedal position sensor A circuit low input
6. P1259 manufacturer controlled fuel and air metering
7. P1508 manufacturer controlled vehicle speed, idle air control and auxiliary inputs
ANY HELP IS GREATLY APPRECIATED THANKS
Old Jan 30, 2013 | 05:36 PM
Former User's Avatar
Default Re: 98 civic with multiple codes please help!!!
Reset the ECU and run the engine to see which codes repeat.
Old Jan 31, 2013 | 05:08 AM
98exb16's Avatar
I'll do that today and make and update you do any of these codes explain why it wouldnt want to idle when cold?
Old Jan 31, 2013 | 07:16 AM
Trouble codes are always potentially useful diagnostic information.
Old Feb 4, 2013 | 09:42 AM
98exb16's Avatar
Icon2 Re: 98 civic with multiple codes please help!!!
What would cause it to starve for fuel on start up only codes are for the coolant temp sensor I replaced the fuel filter plugs and wires they were bad runs great once its up to temp but starves for fuel when the motor is cold is there a check valve in the fuel line or fuel pressure regulator?
ctyler1987
11
May 30, 2014 05:44 PM
silookalike
Jan 30, 2008 05:49 AM
K i l l a B e e.
Jan 2, 2008 01:32 PM
0CooL
Aug 24, 2005 05:12 AM
civictyper99
May 19, 2004 03:57 PM
