93 CIVIC HATCH d16z6 problem
Old Jan 30, 2013 | 03:08 PM
93hatchd16z6's Avatar
Icon2 93 CIVIC HATCH d16z6 problem
i recently changed the injectors and head gasket from my honda civic d16z6 vtec motor but it doesnt want to turn on it only cranks but dont start what can it be cuz the fuel pump is working i check the timing and it seen to be in order wat else can it be ..help plzzz
Old Feb 2, 2013 | 11:50 AM
go-part's Avatar
Default Re: 93 CIVIC HATCH d16z6 problem
Check to see if you have spark.
Check your distributor, plugs and wires.
Old Feb 2, 2013 | 08:11 PM
fonkernuckle's Avatar
firing order on spark plug wires^ then check for spark since you changed had gasket make sure your timing belt is dead on and not a tooth off, remove your spark plugs and see/smell to see if all cylinders are getting fuel (no gasoline on plug= injector not spraying - could be you installed a clogged or inop injector(verify by using a nerd light on the injector connector and crank, it should light when touched to one or the other terminals in the connector= if lights then its the injector thats not firing. hopefully you used oem headgasket and torqued according to helms.
Old Feb 2, 2013 | 09:26 PM
JDMB1692EG's Avatar
^X2 I guess its easier to make a post than to type it in the google search bar lol.
justinrocks
Mar 23, 2015 10:54 AM
sleet_22
Dec 9, 2013 02:09 PM
keister0013
Engine Management and Tuning
Sep 14, 2012 12:43 AM
glockoma818
May 1, 2012 02:43 AM
hmtcrxsir
13
Jan 19, 2008 06:06 PM
