*HELP* 98 Accord stalled, cranks but wont turn over!
Hey guys,
Today i was on my way to work when i noticed i was loosing power as i pressed on the throttle. The RPMS began to drop so i tried pumping the gas, this only seemed to make the rpm's drop even faster until low and behold it completely stalled. I was driving about 45-50 so it was pretty scarry lossing all power steering and such. This has happened in the past about 3 times, each time though it starterd right back up. Also, the last time prior to this occasion was probably 3-4 months ago.
This time it will crank but wont turn over. When i turn the key to the on position i believe i hear the fuel pump kicking in. Is ther another way to test to see if its the pump. Could it possibly be my alternator? It is a 98 Accord with 200k. I woudl really appreciate any thoughts or opinions.
Thanks ahead of time!
Benny
Benny
do you have the 2.3L or the 3.0L? i would get a friend to listen to the fuel pump too see if it kicks in. I would do a sloppy method to see if its fuel not getting delivered by opening up the intake box, pumping the throttle three times then holding it half way as i crank. have you scanned the car yet?
