Engine Coolant Temperature Sensor
its the sensor on the side of the head below the distributor
has a 2 pin plug
the will also be a single pin plug thats the coolant temp sender for the cluster
has a 2 pin plug
Be careful when dealing with fine aluminium threads and use a little sealant on the threads. Removing the distributor will make the job easier but you will then need a timing light.
cruzneel
Aug 27, 2017 12:05 PM
AdamJ2
Aug 22, 2008 11:34 PM
