Sohc/Dohc turbo
These types of posts make me wish new threads in the FI section required mod approval before going live.
Kids these days....
Plain and simply.
If you want a 300+ HP D-series, the engine will need to be built properly (ie. Pistons, rods, headstuds.. etc)
If you want a 300-350 HP B-series, you can do that with a stock (untouched) motor. Although ATLEAST headstuds and a motor refreshing are a good idea. Anything past 350 and piston ring-lands start cracking and breaking apart.
Plain and simply.
If you want to learn, then read this: https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Research is your best friend. Find the SEARCH button and get to know each other...the resources are here if you care to look for them
Who is Mr Robot?
H22s can make more power by default because they have more displacement. The h series aftermarket is a little limited because of it only being in a few us platforms, and due to the frm sleeves, you have to have the block sleeved to use forged internals, so there's a significant cost involved.
Plus they weigh more, so it will throw handling off and you'll need stiffer front springs
H22 Doesent have to be sleeved, mahle makes a drop in piston. A H22 in realty isnt a whole lot heavier then Bswap.. The H22 head is awsome and there is always the H2B options.
The D series in stock for will handle about 220 to 250 whp. Doing to vitara and custom length rods is an awsome option for 350 bucks your good till like 400-600whp. A custom cam regrind is also cheap.
And if a d-serious could make 300hp, what in the world makes you think a b-series wouldnt?
Google is your friend.
Who is Mr Robot?
Yup, they have the thinnest sleeves of any b/d/h motor and are very prone to cracking. That extra 200cc isn't worth the headache over a b18a/b
I would go ls/vtec honestly, I'm building my 2nd and 3rd as we speak... you get the best of both worlds, the torque from the longest stroke crank and the efficiency of a VTEC motor.
Because someone told me single cams are The strongest when built
