Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fuel economy: is this normal?
Old Jan 28, 2013 | 02:15 PM
red_brick's Avatar
Default Fuel economy: is this normal?
Hey all,
I have a 2001 Civic DX 5-speed with 163000 km and I love it, but I have some concerns about my gas mileage. I've owned the car since October, and about 90% of my driving is in the city. I only get about 350 km (or about 220 miles) to the tank, even with liberal use of fifth gear and short-shifting. Is this normal? Am I doing something wrong?
Old Jan 28, 2013 | 02:18 PM
TypeRfit's Avatar
RESIDENT
Default Re: Fuel economy: is this normal?
Doesn't sound right to me, I have a 04' Ex and regularly get 32+ mpg in town driving. When was the last time some general maintenance was done?
Old Jan 28, 2013 | 02:28 PM
red_brick's Avatar
Had it fully inspected when I bought it and changed the oil+filter. P.O. provided receipts to show that timing belt, serpentine belt, and water pump had all been changed recently, as well as some front-end suspension bits.
Old Jan 28, 2013 | 02:44 PM
husyk's Avatar
I had a similar issue, was getting 25mpg with no check engine light. The culprit turned out to be the primary O2 sensor.
Try the following:
-Change spark plugs.
-Change/clean air filter.
-Insure tire pressure is correct.
-Clogged fuel injector, get fuel injector/system cleaner.
-Do not drive like an idiot in a hurry.
-Primary O2 sensor is worn out and needs to be changed.
Old Feb 3, 2013 | 07:17 PM
solex's Avatar
I have an 03 EX Coupe with 67k miles and am getting between 24 and 26 here in Queens and Long Island. I think that this is normal for this type of driving during the winter when the level of ethanol goes up. I have gotten around 34 highway driving.
Should I suspect that my o2 sensor or plugs need changing? Also how do you test the o2 sensor?
Old Feb 3, 2013 | 08:18 PM
Peruviann83's Avatar
that's pretty low MPG. I have an 02 EX and i get 33 MPG and my car has 233k on it. You should definitely do a tune up on your car.
Old Feb 4, 2013 | 06:54 AM
solex's Avatar
Ok, I just order PKJ20CR-M11 DENSO spark plugs, will update when I have replaced them.
Old Feb 10, 2013 | 01:54 PM
solex's Avatar
Plugs have been replaced at 67,833. Old plugs were burning normally, tips were worn. I will keep you all up-to-date on my mileage.
Old Feb 11, 2013 | 04:57 AM
TAParker's Avatar
Try the following:
This is good advice^^^^^^
Old Feb 11, 2013 | 10:46 AM
cb450sc's Avatar
Is there a PCV on this engine? If so, change it as well.
Old Feb 11, 2013 | 11:01 AM
Rick hybrid's Avatar
You can remove it when you're changing the oil & filter and clean it with some carb spray cleaner.
Alex98
Apr 12, 2019 05:04 PM
Kevin_8
May 5, 2015 04:36 AM
Boss727
45
Feb 23, 2014 07:51 AM
dopefeen
May 7, 2007 08:23 AM
tdizz07
Mar 17, 2006 09:20 PM
