HELP CAR JERKS AND POPS FROM PASSENGER SIDE
Old Jan 28, 2013 | 10:20 AM
Havok114's Avatar
Default HELP CAR JERKS AND POPS FROM PASSENGER SIDE
after taking my car to track on slicks 5 passes in the car started jerking and popping when turning , i thought it was the axel so i replaced it and it still does it ! what could it be ? im lost it also does it when im going around 45 miles a hour it willl jerk randomly from the passenger side but it does it worse when turning
Old Jan 28, 2013 | 11:14 AM
Crazed_GSR's Avatar
Default Re: HELP CAR JERKS AND POPS FROM PASSENGER SIDE
Hmm my first guess would have been the front right axle also because I've experienced the same thing recently on my driver side one. Did you replace it with a brand new axle or a spare one sitting around? Chances of two bad axles are slim tho. Maybe jack up the front and do some pulls with it up and have someone look around the wheel well to see if someone thing seems wrong?
Old Jan 29, 2013 | 06:28 PM
Havok114's Avatar
im guessing its the mid shaft or differential
what do you guys think ?
Old Jan 29, 2013 | 06:45 PM
byronl's Avatar
u can check for play jack the car up and wiggle the axle going into the tranny to see how much play u have up down side to side.
Old Jan 29, 2013 | 06:58 PM
Havok114's Avatar
i checked the other day and their wasnt much play at all .
Old Jan 29, 2013 | 09:10 PM
byronl's Avatar
how r ur bushings? check ur wheel bearings?
Old Jan 30, 2013 | 12:47 PM
Solster's Avatar
sounds like the diff. check the tranny oil if it's dark and has metal bits in it you need a newone
bmxkills
Jan 30, 2011 08:53 PM
jwbnavy
Dec 9, 2007 12:38 PM
B16b-EJ8
16
Jan 9, 2007 06:01 AM
nycivic98
10
May 4, 2006 08:11 PM
Muckman
58
Apr 8, 2005 09:18 AM
