Anyone have a BBK 70mm throttle body on their lude?
Old Oct 20, 2002 | 08:17 PM
Que_Lude's Avatar
Default Anyone have a BBK 70mm throttle body on their lude?
I believe that the BBK 70mm does not have any cooling lines on them like the stock TB. Just wondering if anyone had prolems with the idle? I'm in Cali, so it's not too bad. Gets to about 40* F in the winter on a cold day.
Old Oct 21, 2002 | 07:41 AM
BoostedH23a1's Avatar
Default Re: Anyone have a BBK 70mm throttle body on their lude? (Que_Lude)
i had a holley i think it was a 68. i didnt do ****.. petal felt like **** too
Old Dec 24, 2004 | 11:31 AM
cpforyou's Avatar
Default Re: Anyone have a BBK 70mm throttle body on their lude? (BoostedH23a1)
Which BBK throttle body would be the one to use on a Prelude?
This is from their website:
1546 - 62mm Honda Performance Throttle Body 1.5/1.6L
1547 - 70mm Honda/Acura Performance Throttle Body 1.8L/1.6L
1752 - 70mm Integra GSR Dual-Cam VTEC Throttle Body
1753 - 70mm 1996-2001 Integra Type-R Throttle Body
Old Dec 24, 2004 | 01:17 PM
PRCLude98's Avatar
Default Re: Anyone have a BBK 70mm throttle body on their lude? (cpforyou)
I heard the JDM Type S throttle bodies work pretty well... and they're specifically made to fit the prelude intake manifold, not to mention made by Honda, so you know they have that honda fit and finish. If you're looking to spend a little more money, TWM makes more expensive throttle obdies for preludes, but i haven't heard anything about them.
Old Dec 24, 2004 | 01:44 PM
cpforyou's Avatar
Default Re: Anyone have a BBK 70mm throttle body on their lude? (PRCLude98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRCLude98 &raquo;</TD></TR><TR><TD CLASS="quote">I heard the JDM Type S throttle bodies work pretty well... and they're specifically made to fit the prelude intake manifold, not to mention made by Honda, so you know they have that honda fit and finish. If you're looking to spend a little more money, TWM makes more expensive throttle obdies for preludes, but i haven't heard anything about them.</TD></TR></TABLE>
JDM Type S, I'm sure it's nowhere close to 70mm. TWM are individual throttle bodies, and that is not what I'm looking for.
Old Dec 24, 2004 | 01:50 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">Which BBK throttle body would be the one to use on a Prelude?
since the pn 1547 looks like it will fit a wider range of motors that would be my guess.....the coolant lines are for the thermo boost valve....which you can definitely do without in cali.....so go for it
the type s is only 64mm i believe....
Old Dec 24, 2004 | 02:12 PM
v4lu3s's Avatar
RTFM
prelude type-s has a 62 mm TB
i am using a STR 70mm and its nice, i only went with it though cause it fit better on the euro-r manifold so far its nice though.
Andre
Oct 25, 2004 03:18 AM
Fink2iCe
Aug 20, 2004 10:50 AM
jdmcivicferio
Feb 3, 2004 09:49 AM
Black R
Sep 19, 2001 06:53 PM
