bearing lube question
do you lube the backside of the bearing before you put the bearings in or no? i have looked it up and i see yes and no. Im putting my motor together this week and want 100% sure.
thank you
thank you
second question is there a a certain amount of lube to use on the bearings? spread it around or just at the lowest part good enough.
if you think an area is lacking, slop some more on there. Use non sparingly. Its only used for the first time spinning the engine over and getting it started. you cant honestly apply too much, in the context lol.
