FS/FT: Random Integra ITR/GSR/LS part out!!!
Old Jan 27, 2013 | 06:44 PM
justjdm's Avatar
Default FS/FT: Random Integra ITR/GSR/LS part out!!!
Contact: PM's, replies or call/text 518-653-5545
Trades: LMK what you got!
I parted out a 95' GSR 2 door a few months ago and this is everything I got left from it. The more you buy, the better deal I'll give you! Will ship, you just gotta give me your zip code so I can get a quote for you! Let me know if you got any questions. Thanks for looking!!
DB rear trunk carpet (few stains, but no rips/tears)-$30
Kenwood tweeters-$20
Grant Steering Wheel (No horn button)-$25
3/8" Red/blue hose end clamps-$7
OEM Driver and Passenger brake calipers-$25 each
(3) Front corner light wiring harness pigtails with bulb plugs-$15 each
Front turn signal bulb plug-$3
ITR/RS cruise delete switch-$5
ITR/RS Cruise delete for steering wheel w/bracket-$10
Infinity 3 1/2" 75 watt speaker- $10
Orion 4" 80 watt speaker-$10
Pioneer 6 1/2" 100 watt speaker-$5
LS wiring harness- SOLD!!!
Clutch master cylinder fluid reservoir-$5
Fusebox cover-$3
Driverside motor mount-$20
LS thermostat housing- SOLD!!!
Crank Breather-$5
Alternator bracket-$5
LS stiffing bracket-$5
Oil cap-$3
GSR spark plug wires-$5
Front wiper motor -$20
Rear wiper motor-$10
Front wiper arms-$15
Rear wiper arm-$5
Horn-$5
Sunroof motor-$10
Fender brackets-SOLD!!!
Gas door-$5
Passenger side hood hinge-$5
Wiper fluid reservoir w/motor-$10
Hood front weatherstrip-SOLD!!!
Headliner- SOLD!!!
Fuel pump cover-$3
ECU bracket-$5
Ashtray housing bare-$5
Passenger side "A" pillar trim-$5
Steering column plastic cover-$3
Cruise control relay-$5
Dead pedal-$5
OBD1 steering column with ignition/key (will separate if needed) -$40
Stock LCA's-SOLD!!!
Front forks- $5 each
Rear passenger side ABS sensor- $5
GSR cabin harness- $20
Hood latch release cable-$10
Anttena wire from radio to rear hatch-$3
Headliner harness-$5
Driver side upper motor mount-$15
Brake booster w/master cylinder- SOLD!!!
Fusebox cover-$5
Rear bumper support-$20
Seatbelts (front driver side missing)-$30
94-01 GSR DB door panels-130 shipped
These door panels are coming from my 94' GSR DB8. They are in good condition with a few scratches and nicks. Still looks good and fabric not torn/worn out. Will only comes with tweeters that work well, NO switches. NOT spliting these up also, so the price is for all 4!
Parts that got no pics:
Battery wire harness-$5
Crankcase breather-$5
Passenger side door (2 door)-$30
Hatch weatherstriping- $10
Wiper cowl-$10
Rear tail lights inner panel covers (2 door)-$5
Old Jan 28, 2013 | 08:48 AM
justjdm's Avatar
Default Re: FS/FT: Random Integra ITR/GSR/LS part out!!!
ttt
Old Jan 29, 2013 | 08:40 AM
justjdm's Avatar
bump
Old Feb 3, 2013 | 11:11 AM
EL JDM JUNKIE's Avatar
hmm if i get my shell im definitely going to hit you up
Old Feb 4, 2013 | 12:48 AM
justjdm's Avatar
Sounds good!
Old Feb 6, 2013 | 12:10 PM
justjdm's Avatar
ttt
Old Feb 9, 2013 | 07:56 AM
justjdm's Avatar
ttt
Old Feb 12, 2013 | 12:56 PM
justjdm's Avatar
ttt
Old Feb 16, 2013 | 07:56 AM
justjdm's Avatar
ttt
Old Mar 1, 2013 | 06:33 PM
justjdm's Avatar
bump for dropped prices!!!
Old Mar 4, 2013 | 02:26 AM
justjdm's Avatar
ttt
Old Mar 8, 2013 | 12:26 AM
justjdm's Avatar
Ttt
jdmscene87
Mar 2, 2013 02:23 PM
909rex
Oct 7, 2007 10:42 AM
JDM RHD eg6
Nov 20, 2006 10:02 PM
949eg
Nov 9, 2003 06:31 PM
LillDragun
Jul 4, 2002 11:20 PM
