oil leak on 1992 accord ex.
Old Jan 27, 2013 | 04:04 PM
leflore's Avatar
Default oil leak on 1992 accord ex.
I am leaking oil from the distributor. Is there a seal that can be replaced? Other than making a mess,(only have to add oil occassionally) is there harm in just leaving it alone? Thanks
Old Jan 27, 2013 | 04:54 PM
92 civic ex 4dr's Avatar
The harm in leaving the dizzy leaking is exactly what happened to me today in my civic and prior in my accord. Replace the dizzy o-ring. It's cheap and easy. Remove the three bolts holding the dizzy in, cut the old seal off (probably will just break) and put the new one on. If you let it leak the heater hose that is right under it will eventually burst causing you to overheat as it will push all of the coolant out of the system and make a nasty slimy mess under the hood.
Posted from Honda-tech.com App for Android
Old Jan 27, 2013 | 05:18 PM
leflore's Avatar
Default Re: oil leak on 1992 accord ex.
Thanks! Any timing issues if I pull the distributor?
Old Jan 27, 2013 | 05:23 PM
Nope. The cam and dizzy are not center cut they are off center cut so that you can't put the dizzy 180° out.
Old Jan 27, 2013 | 05:32 PM
gdrew888's Avatar
Humm...I could be wrong here but you should put a mark (sharpie felt) near the top bolt area where the distributor bolt attaches to the block as to not loose your timing mark. Should be something on You-Tube that can explain it better than me. Good luck!
Old Jan 27, 2013 | 05:55 PM
leflore's Avatar
Thanks. Think I will tackle it next weekend.
Old Jan 27, 2013 | 06:10 PM
Gdrew888 makes a good point. I forget that the dizzy does turn a little on the forth gen and early to mid fifth gens. Yeah i would use a Sharpie to mark where it sits first. Good point
Old Jan 28, 2013 | 12:52 AM
holmesnmanny's Avatar
ya just make a couple marks where the distributor meets the head so that you can put it back in the same EXACT spot it was...or you'll have to set the ignition timing again..also if the distributor is leaking internally then you need to replace the inner seal, but normally it's just the o ring that sits around the shaft that enters the head...put some oil around the new oring and gently roll it over the shaft..you want to try not to stretch it so don't try to stretch it over the ring..try to roll it over
Old Jan 28, 2013 | 05:34 AM
Darren Thiesen's Avatar
Don't use a "bulk" o-ring from a kit. Get one from Honda. Napa also carries them in their Altrom import line. Altrom part number 562 I believe.
Hold your horses though! Make sure the leak is from the distributor O-ring. There is also a seal inside the distributor that fails. Pull off the distributor cap. If the oil is coming from inside then it is the internal distributor shaft seal. I see this seal leaking all the time. This seal is not available or easily replaced. You will need to buy a new distributor if this is the case.
Old Jan 28, 2013 | 05:39 AM
I just went over that the other day Darren Thiesen. A Dizzy isnt something you exactly want to replace. You say napa carries the Dizzy o-ring? thats great to know, saves me a trip to the dealer today.
Old Jan 28, 2013 | 05:40 AM
the dizzy is kinda expensive. That's why you wouldn't want to replace it.
ronk123
Apr 18, 2017 01:01 AM
N3MeS1Sx
Sep 25, 2010 05:51 PM
Elvis1977
Mar 17, 2009 06:18 AM
vtecjdm
Jun 10, 2004 05:56 AM
AccordCoupe
Mar 4, 2004 02:16 PM
