Battry drain problem
Old Jan 27, 2013 | 09:07 AM
Lizardslap's Avatar
Default Battry drain problem
OK the car is a 96 del sol 5speed recently converted the throttle body to y7 from y8
ok so Im getting 37.5milla amp draw
So far I have pulled every relay and fuse under the hood and dash including the main relay 1 at a time and none changed it
the throttle body change I completely snipped the whole modification out to see if that would change anything Nope just more soldering fun for later.
when I jumped the car I was getting 12.5v and it slowly increased up to almost 13v the alternator is 2years old and has never given me a problem as of yet But Im gonna go disconnect that to
anyone got some Ideas or somthing
found out next time this happens disconnect the alternator first it was a bad alternator
Old Jan 27, 2013 | 11:10 AM
Former User's Avatar
Default Re: Battry drain problem
37 mA drain is normal.
Is you battery losing charge? Have you tested the alternator?
Old Jan 27, 2013 | 11:50 AM
Lizardslap's Avatar
the battery was draining pulled the alternator and had it tested it was bad.
Idk why it was new as of 2 years ago but thank you lifetime warranty
Old Jan 27, 2013 | 12:33 PM
Some alternators come bad out of the box.
CheeriosTM
Dec 8, 2011 10:31 AM
prelude182
Apr 21, 2010 12:40 PM
Choy
20
Jul 20, 2009 07:11 AM
MidShipCivic
Acura TL, RL & ZDX
Nov 5, 2006 03:12 AM
rasta420
Oct 2, 2006 04:46 PM
