B18b1 eg hatch upgrade to b18c5
Old Jan 26, 2013 | 05:44 PM
robbie1789's Avatar
Default B18b1 eg hatch upgrade to b18c5
alright first off im new to this forum hi guys, and sorry if i post this in the wrong area still learning this forum but ok heres my question i just recently got a 93 eg hatch with a b18b1 swap in it and its obd1 so i was wondering i want to get a beefier motor like the c5 or c1 but just trying to figure out if i can use the wire harness on my ls on the vtec engine i know ill need a vtec ecu just curious on the whole wire harness stuff but say i get the engine and it comes with an wire harness on new engine will connect to the one i have on it now thats connected to my ls anything will help and thanks guys
Old Jan 26, 2013 | 07:38 PM
GagnarTheUnruly's Avatar
Default Re: B18b1 eg hatch upgrade to b18c5
It will mostly work but there are some connections you will need to make yourself. I don't remember them off the top of my head but VTEC solenoid and knock sensor come to mind. It's been discussed many times though so searching may give you the answers you need. As far as I am aware it is pretty rare for people to swap harnesses when they swap VTEC engines into LSs, given the cost and difficulty of doing so.
Old Jan 27, 2013 | 08:50 AM
robbie1789's Avatar
Thanks I've searched didn't find anything I must be asking the wrong question tho. I need to find these topics ur talking about should help me quite a bit. But thanks once again.
Old Jan 27, 2013 | 08:58 AM
See if this helps:
https://honda-tech.com/forums/acura-integra-6/gsr-swap-ls-stupid-harness-plug-question-2801875/
Old Jan 28, 2013 | 04:08 PM
robbie1789's Avatar
Answered all my questions man thank you for your time. Will be purchasing a gsr engine soon
Old Jan 29, 2013 | 09:21 AM
Eg.ls.turbo's Avatar
Yep just wire up vtec sensor, vtec pressure switch, knock sensor, and Iacv. I'm doin the same engine swap in my eg too just more of a stroker gsr
robbie1789
Classic Hondas
Feb 5, 2013 10:05 AM
96tealteg
Nov 5, 2012 06:21 PM
GSR936
Feb 18, 2010 05:55 AM
orange94teg
Mar 25, 2008 08:52 AM
MrSparky
May 21, 2006 10:21 PM
