Suspension Help?!
Old Jan 26, 2013 | 03:57 PM
JJFreshy's Avatar
Default Suspension Help?!
I just swapped out some ebay coilovers that were on my EF sedan with GC's. When swapping over the OEM top mounts with all the OEM hardware I did not have enough thread to get the top mount nut on. I tried without the washers and the shock just goes through the upper mount so that doesnt work. I ended up leaving out a bushing.
Anyone have any experience with this? I tried to follow this diagram (link below) and install all the same washers and bushings but again, did not leave enough room to thread the bolt.
http://www.myhondapartsstore.com/myh...3s0201_b30.png
Old Jan 26, 2013 | 08:19 PM
civexspeedy's Avatar
Default Re: Suspension Help?!
What shocks are you using? Are they the same as the ones you used with the ebay set?
If you're using the same shocks that you used with the coilovers from ebay, nothing should have changed as far as the shock and top mount.
Old Jan 27, 2013 | 08:17 AM
zorrobyte's Avatar
Got a pic? I think that the shock stroke is too short to reach.
Old Jan 27, 2013 | 01:49 PM
ghosthatch's Avatar
compress the spring while installing? then get the nut on
Old Jan 27, 2013 | 07:25 PM
Jockone's Avatar
Do you have the spring seats turned up or are they down low?
Old Jan 27, 2013 | 07:48 PM
Tyson's Avatar
i cant imagine this scenario with GC kit.
usually youd have the opposite.
what is the length of the spring?
do you know how to read the numbers? if not, just tell us the numbers printed.
EG-SIXV-TEC
Suspension & Brakes
17
Jul 19, 2012 11:53 AM
beanbag
59
Aug 19, 2009 05:35 AM
dirtyharryhatch
Suspension & Brakes
Jun 21, 2008 05:10 PM
ex_ricer
Suspension & Brakes
Jan 21, 2008 07:00 PM
slowls
May 12, 2004 03:17 PM
