97 Civic HX/D16Y7 swap - iacv (P1509) and o2 sensor (P0135) CEL codes
Old Jan 26, 2013 | 12:29 PM
tecatown2091's Avatar
Default 97 Civic HX/D16Y7 swap - iacv (P1509) and o2 sensor (P0135) CEL codes
I need help .I brought a 1997 civic hx coupe I has a y7 in it .and he said the o2 sensor needs to be replaced .which he lied .but I cleaned the iac out and it runs alright a little low rpm around 500-600 rpm idle .but the iac is a 2 wire .should it be a 2 wire .did he switch the motor out and not change the plugs he needed .it has p1509 and p0135 .I need some help.what should I do .
Old Jan 26, 2013 | 12:52 PM
Default Re: iac and o2 sensor help
no help anyone????/
Old Jan 26, 2013 | 02:22 PM
Former User's Avatar
What ECU and transmission?
If you reset the ECU, do both codes return?
Is 7.5A dash fuse 15 blown?
Old Jan 26, 2013 | 02:25 PM
manual .and how do i check what ecu it is .i will check it when i get home.ive reset ecu by battery and fuse
Old Jan 26, 2013 | 02:26 PM
Default Re: 97 Civic HX/D16Y7 swap - iacv (P1509) and o2 sensor (P0135) CEL codes
The ECU is located behind the plastic front passenger kick panel. The ECU will have an ID label on it. Post a picture or the ECU code.
Old Jan 26, 2013 | 03:06 PM
redtherocket's Avatar
d16y7 manual is 3 wire
you need one of the following ECU's.... p2e-a01, p2e-a02, p2e-a03
Old Jan 26, 2013 | 03:13 PM
will that fix p1509 and p0135?
Old Jan 26, 2013 | 03:19 PM
and how do i put a 3 wire to it .
Old Jan 26, 2013 | 03:20 PM
p0135 is for a bad primary O2 sensor....(front one)
P1509 is for IACV malfunction...
What intake manifold is on the car...? A stock Y7 with the filter on the manifold?
What ECU do you have?
Old Jan 26, 2013 | 03:25 PM
im not sure he told me its all stock but when i ran the p0135 it said bank 1 sensor 2 . which the dude at oriley told me its the downstream one .im not sure the intake manifold i will post pics when i get home .car runs pretty gud just wont pass emissions
Old Jan 26, 2013 | 03:30 PM
Post pics
Old Jan 26, 2013 | 03:31 PM
This^ is wrong as mentioned.
Old Jan 26, 2013 | 03:32 PM
^Also correct. You need to find a 3-wire IACV.
Old Jan 26, 2013 | 03:45 PM
how do i do that? buy a iac for a different engine?then how do i wire it
Old Jan 26, 2013 | 03:47 PM
Start by looking for a junk yard 96-00 D16Y7 engine and buy the 3-wire IACV.
Old Jan 26, 2013 | 03:49 PM
when i get the wire .how do i rewire 2 wire to 3 wire
Old Jan 26, 2013 | 03:59 PM
Before you do anything, you need to show us the manifold...
And the IACV on a Y7 is auto/manual specific.....
Purple Denso sticker = Auto...
Blue Denso sticker = Manual...
Wiring it will require you to install a pin out in the empty slot on the ECU plug..
FFsquad has the diagrams and pinout locations...
It won't be that hard...
But first...PICS.
Old Jan 26, 2013 | 04:52 PM
But first...PICS.
the iac toward the back of intake .if that helps till later
Old Jan 26, 2013 | 05:21 PM
But first...PICS.
do i have 2 iacs? one on back of intake.one connected to the tb?
Old Jan 26, 2013 | 05:25 PM
I believe that the auto and manual IACVs for the D16Y7 are the same.
Old Jan 26, 2013 | 05:26 PM
no.
I'm led to believe from your description that the original owner used a replacment Y7 head/block and used the HX intake/exhaust manifolds and used the Y7 ECU...
Just a guess..
Old Jan 26, 2013 | 05:33 PM
Whether its OBD version, a revision, or drive specific, All IAC's for 96-2000 aren't the same on the Y7 from dealing with some idle issues on my 97.....
I tried one from an auto, and it was sending the rpm to fuel cut..
I noticed, some are spring loaded... Some are not...
No visual difference other than that sticker..
Old Jan 26, 2013 | 05:43 PM
Hmmm...You may be right. I just compared IACV part numbers for the 97 Civic DX manual versus auto and they are different. Good to know.
Old Jan 26, 2013 | 06:03 PM
no.
I'm led to believe from your description that the original owner used a replacment Y7 head/block and used the HX intake/exhaust manifolds and swapped in the Y7 ECU...
Just a guess..
i talked to a local mechanic he thinks i have the wrong ecu .he said if its different then 1997 civic hatchback its wrong for the y7.and would throw those 2 cels.Correct?i will check the ecu when im home
Old Jan 26, 2013 | 06:06 PM
pics
good ones...
Show the IACV connection..
