Gas mileage question
Old Jan 26, 2013 | 12:53 AM
Jessaaaaay's Avatar
Default Gas mileage question
How many miles do you guys on average get on a full tank if you have a 90-93 accord?
Old Jan 26, 2013 | 04:51 AM
Accord1320's Avatar
Default Re: Gas mileage question
Between 350 - 375 for the tank using 87. Some people might say that using 91 or other higher octane will prolong the mileage is a myth. I've done that for a few months, and thought I did okay. And when I finally tried 87 (which is what the manufacturer recommended in the first place), I actually got more miles and saved at the pump. (I actually did some figure checking by recording my progress for months using 87 and 91, going from the highest point of the full gauge all the way down until the gas light came on. Huge difference costwise at the pump.)
Don't use higher octane unless the manufacturer recommends or if your ride is boosted...
Old Jan 26, 2013 | 06:42 AM
jakescakesz06's Avatar
www.fuelly.com
Old Jan 26, 2013 | 07:27 AM
92 civic ex 4dr's Avatar
Using the higher octane than manufactures recommend won't increase your fuel mileage. I have personally tested it. If the engine isn't high compression there is no use using a higher octane fuel. It actually brings your mileage down. Like i said i have personally tried on my Jeep V8 civic 92 and accord 97. Got the same results from all.
Posted from Honda-tech.com App for Android
Old Jan 26, 2013 | 10:40 AM
Jessaaaaay's Avatar
Okay now I feel sucky. I notice I only get around 200 on mine. Any ideas whats decreasing my mileage?
Old Jan 26, 2013 | 10:53 AM
Well it depends in how you drive as well as how the vehicle is operating. If you haven't done a FULL tune up, then i would suggest you do that. Especially change the fuel filter. A clogged filter will decrease you mileage a lot. Just do the usual. Fuel filler, cap, rotor, plugs, wires, oil and filter change, pcv valve, and air filter.
Old Jan 27, 2013 | 09:30 PM
Jessaaaaay's Avatar
I see. That's true. I've done all the oil, pcv, fuel filter, air filter. Not the wires tho. My whole distributor set are pretty new (3 months old). Ill check more on my stuff. Thanks for info.
Old Jan 31, 2013 | 09:14 AM
Bad_dude's Avatar
Is your car an auto or manual? My car is auto and it around 300-320 to the tank. However, I fill it up once it's down to the quarter full. My gas mileage is around 19-26 depending on how much freeway I use.
Old Jan 31, 2013 | 11:14 AM
professorman's Avatar
I get about 350 around town and 400+ miles for 100% highway driving with cruise control.
JDM KING
16
Jan 17, 2011 04:13 PM
2k.civic.si
Sep 30, 2010 01:30 AM
KraZyCHOWMEIN
Jun 19, 2008 05:30 AM
OoHiTzToMMy
Oct 13, 2003 08:22 PM
Adampops
Feb 21, 2002 07:56 PM
