Infinity Kappa 62.9i install questions
Old Jan 25, 2013 | 09:30 PM
KevinVX's Avatar
Default Infinity Kappa 62.9i install questions
Hello, I am trying to install my 6.5" Infinity Kappa 62.9i speakers into my 1995 VX hatchback. I was wondering whether I would have more clearance with a set of aftermarket speaker adapters such as this one versus modifying the original brackets by cutting out the backing that stops my speakers from sitting flush inside the bracket as depicted below. I was also wondering if anyone has had any issues with their speakers rubbing against the speaker grilles at higher volumes?
Old Jan 25, 2013 | 11:15 PM
mechanix619's Avatar
Default Re: Infinity Kappa 62.9i install questions
Mount the speakers to the actual door. When mounted to the panel there tend to be a lot of vibrations.
Old Jan 26, 2013 | 08:25 AM
KevinVX's Avatar
That would be awesome except my window doesn't roll all the way down when the speaker is placed against the actual door and the mounting holes do not line up either.
Old Jan 26, 2013 | 08:51 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Dont just mount the speaker to the door. It will sound like poo... Build a baffle ring or cut out the oem plastic one and use it. The pannel is not going rub on the speaker at high volume. There is not that much excursion on those speakers.
Old Jan 26, 2013 | 09:29 AM
KevinVX's Avatar
I guess I will try modifying the original brackets. Thank you.
Old Jan 26, 2013 | 01:35 PM
fcm's Avatar
fcm
Old Fart
Better yet, replace the stock plastic speaker mounting "brackets with custom MDF speaker mounting plates, the stock plastic housing can be used as a template so you can use the same mounting points, cur a hole in the plate to match your Infinity speaker mounting hole diameter, use thick enough MDF so speaker magnet clears the window.
A speaker mounted to wood will always sound better then one mounted to plastic and as mentioned mounting a speaker to sheet metal will sound like poo. 94
thevirgin
Jan 13, 2008 05:05 PM
gator88
Aug 31, 2006 02:27 PM
chris3k
Audio / Security / Video
Feb 7, 2006 02:51 PM
Team PHATBOYZ
Nov 17, 2005 01:38 PM
Sam
Dec 20, 2002 08:15 AM
