Sparkplug for high compression
Old Jan 25, 2013 | 08:24 PM
The_Head's Avatar
Default Sparkplug for high compression
I'm getting ready to have my engine tuned. It's a 2414 cc H22A with 13.5:1 compression. Will be tuning it on at least 93 octane.
What heat range plug do I need to get? I'm thinking 6, but I want to make sure.
Old Jan 25, 2013 | 09:17 PM
98vtec's Avatar
moderator emeritus
Default Re: Sparkplug for high compression
hope you have a sufficient head to run that on pump gas. its been awhile since i have bought plugs for my race car but the ones i am running show perfect heat range although you choice in fuel is dependent on heat range as well. run e85 or get a thicker head gasket.
2 cents
Old Jan 25, 2013 | 09:26 PM
The_Head's Avatar
If you think I need to up the octane, I can, as the car is just a toy and won't be daily driven. E85 is not an option as there are no E85 stations in my area.
The car will be ran at 4,000 ft altitude.
TheShodan's Avatar
Moderator
7 heat range is about what you can do.
Old Jan 28, 2013 | 07:26 AM
Nsx2007's Avatar
Use NGk
Dre90
Mar 28, 2010 07:43 PM
Evolsport
Jul 17, 2009 12:44 PM
hondab18civic
Feb 6, 2006 07:24 AM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
topsekret
Aug 28, 2002 03:51 PM
