Idle problems after car is warmed up @ start.
Hello everyone,
I hope you can all help me with this. In the morning i start the car, this is the first time my car is getting turned on and it's been sitting overnight. It starts fine and it has no problems. Now my problems start happening on my second start, after it has been warmed up. For example, if I go to the store (at this point my car is fully warmed up) and shop around 15 to 20 minutes. When I go to start my car the second time around it has a low idle and it feels like it wants to turn off. This happens for about 5 seconds and then it goes back to normal 750 to 800 rpm. After that the car runs fine until the next start. This only happens at start and when the car is warmed up. It's been happening for a month now. My car is a 97 Acura Integra LS, MT. I have replaced the following.
Spark plugs ( 11 months ago).
Spark plug Wires ( 1 month ago).
Idle Air Control Valve (2 days ago) I thought it was this.
Distributor with rotor and cap (2 Months ago).
Oxygen Sensor from headers (1 month ago).
Compression is fine (tested 1 month ago by mechanic).
No coolant in engine (tested 1 month ago mechanic).
Engine coolant temperature ( tested 1 week ago).
Tested the fuel pressure visually (2 months ago).
Radiator replaced with all water hoses (3 months ago).
Full timing belt kit (water pump, all belts, seals) (4 months ago).
I check the vacuum hose that are relevant. I don't know exactly where are all of them.
Any suggestions or should i start looking for a new car. lol
Hmm interesting to come across this post. Not trying to thread jack but I have an 00 gsr. First start up is perfectly fine, but if I turn it off then lets say wait a minute or a few then start again, seems like it was barely able to crank and rpm is in the low 100s around 300-400 only. Curious to find out what the problem is
Once again, not trying to thread jack, just have an issue that sounds very similar to yours. Hopefully some veterans can drop some knowledge for us
$amGD3
Apr 10, 2015 07:27 AM
joe_accord23
Aug 21, 2010 10:45 AM
sohcVTEK
Jun 18, 2006 08:44 PM
