93 Del Sol Turn signals and hazards stopped working
Okay so a couple days ago I started driving my car and all of a sudden the turn signals and the hazards aren't working anymore. They don't work outside and they don't work in the cluster either. When I engage them I dont even hear the clicking noise like you would normally hear. I checked all of the fuses underneath the dash and in the engine bay and all of them are good. I double checked to make sure fuse #15 is good. I also replaced the flasher relay that I circled in red on the diagram. I'm not sure where to go from here. Anyone have an idea as to what the issue could be?
Ok. Not sure what that part in the fuse box really is. It's labeled TO turn signal hazard relay. My Shop manual shows the actual turn signal/hazard relay being mounted on a bracket in the drivers foot well. Same bracket as the aux light relay. It should have 6 wires going to it.
Alright so here is the scoop. After I read your reply above I went back and found the actual relay. Its behind the fuse panel to the left of the clutch. It actually had 9 wires going into it but it does have 6 connectors on it. I took it to the auto parts store to get a replacement and found out it is $125. Don't even want to imagine what it cost at the dealer. So tomorrow I will be going around to junkyards to find a replacement. I hope it works! Thanks for your help!
But for sure I'll be scrounging a couple at the next pull a part trip
tallguy21
May 17, 2012 04:13 PM
5thGenFanatic
Nov 6, 2006 10:32 AM
