1997 Honda Civic Cluster light doesnt work
Old Jan 24, 2013 | 02:16 PM
lilchris813's Avatar
Default 1997 Honda Civic Cluster light doesnt work
im having trouble with my cluster light i had cut the wires from the 2 front speakers from the main harness to connect it with an amp and now the cluster light dont work any help plss?
Old Jan 24, 2013 | 02:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 1997 Honda Civic Cluster light doesnt work
Did you check to see if you blew a fuse? Both underhood and in cabin? If so, put the wiring back the way t was. Do the cluster lights work again?
Old Jan 24, 2013 | 02:29 PM
i did check all the fuses their fine and i will try that when i get home i havent tried that yet the thing is i make sure it was the same colors from the door wires to the main plug i dont get what door speakers have to do with cluster light?
Old Jan 25, 2013 | 06:56 PM
BumperHumper307's Avatar
if you look here http://www.the12volt.com/installbay/...tail/1050.html you will know what wires to use, also you don't have to cut them to splice into them. http://www.summitracing.com/parts/up...FStgMgodpRIAwA those will make your life smoother and not hack your ride.
Old Jan 29, 2013 | 12:31 PM
the thing is i had cut only the front + and - for both speakers i did not touch anything else?
i tried jumping the dimmer switch with a paper clip and did not work either i jumped red to black wire still didnt come on ? maybe theres no ground but i cant find where the black wire leads too ?
any more helpppp
Old Jan 29, 2013 | 12:38 PM
Former User's Avatar
Post pictures of the cut wires. The cluster lights use three wires -- Red/Blk, Red, and Blk.
Check 7.5A dash fuse 30.
Old Jan 29, 2013 | 12:42 PM
alright i will when i get home
and i already checked the dash fuse and box for inside lights theyr good
btw thanks for the help !
Old Jan 29, 2013 | 12:43 PM
Voltage test fuse 30 - click the test fuses link in my signature.
hellaflushdb2
Aug 10, 2011 04:31 PM
mugencivic94
Aug 17, 2007 09:54 AM
HondaIntegraGSR
18
Dec 12, 2006 06:10 PM
D1AUTO
Jun 24, 2005 06:42 PM
hothotpete
May 3, 2005 06:20 PM
