2nd gear grind
Old Jan 24, 2013 | 12:03 PM
donepps's Avatar
Default 2nd gear grind
Hi guys
About 2 weeks ago I had my slave cylinder go out and the clutch pedal was stuck to the floor, in order for me to get it changed I had to drive it down the street to a shop without a clutch, when doing this I sort of pushed it into second gear while fiddling with the clutch and it grinded into second. After a successful slave cylinder change I noticed 2 things:
1. The clutch is on its way out because it is slipping in almost every gear.
2. Every time try putting the car into 2nd gear it grinds.
I have changed the transmission fluid using GM Synchro Mesh which didn't really do anything for the 2nd gear grind. I asked 2 different mechanics and both of them say it is a problem with the clutch and not the transmission but having owned a few preludes now I know that it could be a problem with the 2nd gear synchro. Now my question is: is it possible for the clutch to only cause grinding in 1 gear?
A few other things: If the car is not moving or moving really slow at low rpms there is no grind. When the car is off it slips right into gear with or without the clutch as usual. Lastly if the car is on and the clutch is not pressed, I push the shifter toward 2nd gear and it starts grinding unlike any other gear.
Old Jan 28, 2013 | 03:57 AM
Shadowcat's Avatar
Default Re: 2nd gear grind
just wear and tear. unfortunatly from the way you describe it it is not comming from the clutch. your second gear synchro is almost gone. hence if you shift it slow the gears arnt forced so it doesnt grind. tear apart the tranny and replace all the synchros and youll be good.
Old Jan 28, 2013 | 10:53 AM
bairdandrew77's Avatar
I agree with Shadowcat, it seems like normal wear. I don't think this problem is very uncommon for Honda transmissions.
Old Apr 6, 2013 | 09:36 AM
donepps's Avatar
It was the 2nd gear synchro that was causing the grind, it was replaced while the clutch was being replaced.
gabe768
Jun 7, 2010 03:06 PM
integracura
Apr 18, 2007 11:18 AM
B18cteg
Jul 3, 2003 10:18 AM
ITR111
Mar 15, 2002 06:09 AM
Type R 702
Nov 19, 2001 01:25 PM
