B16 wont heat up
Old Jan 24, 2013 | 09:13 AM
dafreeeze's Avatar
Default B16 wont heat up
I have a 93 eg with a b16a. The temp guage seems like it only works when im idleing and wont go past the bottem marking on the guage if im driving on the highway it only moves when idle any idea what could be the problem im in canada and its to cold for it not to be working. Thanks guys
Old Jan 24, 2013 | 09:17 AM
JuggerNaut-CTR's Avatar
Default Re: B16 wont heat up
check if the thermostat is closing...replace if needed
bleed the cooling system as well
*edit* closing
Old Jan 24, 2013 | 09:58 AM
thatcivic96's Avatar
+1 for thermostat. I would assume stuck open, so coolant is always flowing not allowing the engine to heat up. I am assuming your heater does not get very hot either? If you have not replaced it lately, it is cheap and easy to replace.
Old Jan 24, 2013 | 10:15 AM
dafreeeze's Avatar
The heat in the car only gets like luke warm just enough to barely defog the windows. I am mechamically inclinded where is it located and if i remove it will all the coolent in my car **** all over the place?
Old Jan 24, 2013 | 10:21 AM
All of it won't leak out, just what is at the point, you will have to add antifreeze when done, a moderate amount will leak out. Follow the Rad hose until you get to the water neck. It will have 3 bolts on it. Passenger side of the motor pretty much where head and block meet at the back corner.
Old Jan 24, 2013 | 11:28 AM
kyden's Avatar
^^ that's not where the thermostat is. that pictured is the upper water neck.
Old Jan 24, 2013 | 11:33 AM
Damn you are correct I did not pay close enough attention the picture, the thermostat isn't even on this one yet...
Old Jan 24, 2013 | 11:36 AM
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/hellpppp-b16a-thermostat-gaskets-2153742/
Post #5 there explains step by step.
Old Jan 24, 2013 | 01:08 PM
cvcrcr99's Avatar
http://www.hondacivicforum.com/forum...acement-81130/
Made by yours truely
Let me know if you have any quesitons.
Old Jan 24, 2013 | 01:42 PM
VtecCivic93's Avatar
Having this same issue with my 99 Civic Si.
Althought I think I let a giant bubble in when i cracked open the radiator cap with the engine running. DOH!
Old Jan 24, 2013 | 01:55 PM
grumblemarc's Avatar
The Grumpiest
If you know the system has air in it then bleed the air from the system.
Old Jan 24, 2013 | 02:00 PM
Lol, I plan to. I just purchased the car last night and haven't had time to do anything with it really.
Old Jan 25, 2013 | 01:52 PM
dafreeeze's Avatar
Thanks guys i replaced there tstat and now my heat is pumpin
thugsbryan
Apr 14, 2016 06:02 PM
jdm36
29
Dec 17, 2010 06:59 PM
drjay2022
Jan 16, 2006 08:12 AM
blueicexxx1
Dec 15, 2005 09:28 AM
s1ngle
Dec 12, 2005 05:26 AM
