Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
FS: K20Z3 tranny part out
Old Jan 24, 2013 | 06:24 AM
DFW's Avatar
DFW
Default FS: K20Z3 tranny part out
Some parts are off a 07 tranny, the rest are off a 09 tranny. 30-40k miles on all parts. LSD and Final Drive are damaged. Carrier Bearings on the LSD assembly feel/look ok (not pictured yet, but can if needed).
Let me know if you would like more pictures of a specific piece.
Gears: $40 each
Forks: $20 each
Reverse gear and shaft: $25
Carrier bearings: $10 each
Oil gutter plates: $5 each
Back-up light sensor: $10
Tranny upper case: $100
Everything else you see: Give me an offer
Parts sold:
-shift mechanism
-all 3 shift forks
from countershaft:
-2nd gear
-1st gear
-1-2 synchros
-2nd gear hub
-2nd gear sleeve
-4th gear
from mainshaft:
-3rd gear
-3-4 complete synchro set
-carrier bearing
-4th gear
There are no duplicate pictures, I just turned the item around to the other side for a picture.
Old Jan 28, 2013 | 07:47 AM
DFW's Avatar
DFW
Default Re: FS: K20Z3 tranny part out
bump.
Old Jan 28, 2013 | 09:55 PM
95k20eg6's Avatar
How did the LSD get damaged and do you have any pics of it?
Old Jan 29, 2013 | 10:37 AM
DFW's Avatar
DFW
it cracked in 2 spots...
http://farm9.staticflickr.com/8510/8...55a57ee0_z.jpg
http://farm9.staticflickr.com/8052/8...436397af_z.jpg
Old Jan 31, 2013 | 04:09 PM
DFW's Avatar
DFW
bump
Old Feb 3, 2013 | 04:13 AM
DFW's Avatar
DFW
bump
Old Feb 6, 2013 | 05:20 AM
DFW's Avatar
DFW
bump
Old Feb 11, 2013 | 02:37 AM
DFW's Avatar
DFW
bump
Old Feb 16, 2013 | 05:23 AM
DFW's Avatar
DFW
bump
Old Feb 27, 2013 | 05:23 AM
DFW's Avatar
DFW
bump
Old Mar 15, 2013 | 12:02 PM
DFW's Avatar
DFW
updated parts sold list
Old Apr 2, 2013 | 12:07 PM
DFW's Avatar
DFW
this is all that is left...tranny case and sensors not pictured but still for sale. for more detailed pictures go to the original post.
mainshaft: 5-6 synchros and rings, 5th gear, 6th gear, needle bearings.
countershaft: 3rd gear, 5th gear, 6th gear, needle bearing.
miscellaneous: Reverse gear and shaft, reverse shift fork, case bolts, dent bolts, sealing cap, drain bolt, oil gutter plates.
to the left of the oil gutter plates are main, right side are counter
DFW
Apr 2, 2013 12:07 PM
jdmkid8383
Jan 3, 2008 06:50 PM
iBrandon
Aug 23, 2007 12:17 AM
hooptie157
Oct 19, 2002 02:22 AM
