Losing power to radio
Old Jan 24, 2013 | 05:49 AM
Xathine's Avatar
Default Losing power to radio
When I shut my car off, I lose power to my radio.
As in, when I get back in the car and turn it on all my presets have been erased and I have to enter the anti theft code.
Any ideas?
Completely stock 94 del sol
Old Jan 24, 2013 | 06:22 AM
Former User's Avatar
Default Re: Losing power to radio
Newly installed radio or new problem with radio that has worked fine in the past?
Is the 7.5A hood Back Up fuse blown?
Old Jan 24, 2013 | 06:33 AM
Xathine's Avatar
I just purchased the car don't know too much on it.
It had some shitty walmart head unit installed. I removed it and put an OEM unit from my other car in (worked perfect in my 97)
None of the wiring is hacked anything.
I'll check the fuse here on my lunch break.
Old Jan 24, 2013 | 06:36 AM
You'll probably find the hood fuse blown.
Old Jan 24, 2013 | 07:07 AM
Xathine's Avatar
Wasn't even a fuse in there.
Popped one in and everything works flawlessly!
Thank you very much.
My next problem is my horn not working.
Old Jan 24, 2013 | 07:20 AM
Hood fuse?
Old Jan 24, 2013 | 07:59 AM
Xathine's Avatar
Fuse is good
Old Jan 24, 2013 | 08:45 AM
eghatch9295's Avatar
Stancetard Hate Monger
do you hear the relay click when you hit the button?
Old Jan 24, 2013 | 08:54 AM
grumblemarc's Avatar
The Grumpiest
Aftermarket wheel?
Old Jan 24, 2013 | 09:31 AM
Xathine's Avatar
Bone stock.
No noise when hitting horn button.
Old Jan 24, 2013 | 09:52 AM
Do the brake lights work?
If you run power and ground wires directly from the battery to the horn, does it sound?
Old Jan 24, 2013 | 10:11 AM
thatcivic96's Avatar
Sounds like a dumb question, but is the horn itself even there? I looked at every fuse on my girlfriends car before thinking to look if it was even there.
Old Jan 24, 2013 | 10:27 AM
Xathine's Avatar
Brake lights work.
Horn is installed.
I'll find some wires and try to manually sound it here in a few
Old Jan 24, 2013 | 10:33 AM
Yeah could be an issue with the wires on the steering wheel then. If my memory serves me correct you have to take the air bag off the steering wheel to get to those wires, but they are connected in the column somewhere.
Old Jan 24, 2013 | 10:53 AM
Xathine's Avatar
That probably has something to do with it then.
I removed the SRS unit, wiring and passenger airbag.
I wonder if it is tied into the SRS system?
Old Jan 24, 2013 | 10:55 AM
Did you remove the driver's airbag and cable reel in the steering wheel?
It is not tied into the Srs system, the SRS system is on it's own system and is wrapped in yellow everything with yellow connectors. However if you took the driver's side bag out you may have damaged a wire or disconnected one on accident. I have a spare wheels and airbag at home I will take a look at when I leave work if you have not figured out the problem.
Old Jan 24, 2013 | 11:20 AM
The Grumpiest
Reading comprehension. He did not ask specifically about the SRS system. The question was "Did you remove the driver's airbag and cable reel?"
Old Jan 24, 2013 | 11:22 AM
If you are referring to me I am not the OP and was giving OP more info on the system and telling him that it is it's own system since he had asked if it was on same system. Thanks though.
OPs inquire about SRS system being tied into the power system for horn:
Old Jan 24, 2013 | 11:47 AM
Xathine's Avatar
Negative.
Only removed srs unit, passenger air bag, and yellow wiring associated with it.
Drivers side air bag hasn't been touched aside from removing the yellow.
Old Jan 24, 2013 | 11:51 AM
Well there goes that idea, I would check horn with pos neg leads straight to battery see if it work then report back.
Old Jan 28, 2013 | 07:16 AM
Xathine's Avatar
probably gonna have to use jumper cables to connect pos and neg leads is that gonna be okay?
and my cruise control has stopped working as well
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
DEEPfrom1
11
Feb 8, 2009 10:03 AM
ScottieA
Jan 23, 2006 12:01 PM
antivic
Jun 7, 2004 10:44 AM
AssPenny
Jan 7, 2002 09:29 AM
