99' EM1-oil burning smell
Old Jan 23, 2013 | 06:45 PM
jdm_phunk's Avatar
Default 99' EM1-oil burning smell
So Im kinda stumped on this one.
99' civic SI
115k mi
no mods
28 mpg avg= normal
Here is everything I looked over and confirmed.
Oil burning smell *
-only at idle- smell through air vents when set on outside air(of course)
-only at operating temp. no smell when cold (of course)
-no fluids burning on exhaust pipe-anywhere
-engine does not have any oil leaks anywhere. (since I have owned the car I have put a rear main seal/lower pan gasket.)
-No other leaks of any other fluids-coolant/brake fluid/pwr steering.
-*engine is not burning oil- I change the oil every 3000mi- dip stick shows full when I hit 3000miles for the past 6 oil changes.
- **NO smoke out of the tail pipe at all. In any conditions- idle/cold start/operating temp/WOT
- no DTC's at all.
-Engine is completely bone stock.
- I know the previous owner and he did every maintenance at Honda(per service book-older guy in his 50's)
-Only thing I can think of and have not checked yet is PCV valve sticking.The PCV has never been change to my knowledge and rubber seals(on PCV/baffle box) are hard as a rock.
(@ idle in theory = highest vacuum- sucking oil fumes<--oil smell? I know PCV goes into the IM and fumes cant escape into atmosphere. But IDK what else to check out.
RonJ@HT any suggestions?? anyone? thanks
Old Jan 23, 2013 | 07:38 PM
jbpnoman's Avatar
Default Re: 99' EM1-oil burning smell
A new PCV is cheap, and it wouldn't hurt you to replace it anyway. I would also closely inspect the length of your exhaust for any signs of cracks or damage.
Old Jan 23, 2013 | 07:51 PM
jdm_phunk's Avatar
Replaced donut gasket in front of cat 7k ago, Could not find any black soot/air leak noise at gaskets and welds. Ill be changing the pcv/seals this sat. I thought of this, this is a some what common issue(welds causing exhaust leak/smell on some older nissan's. (im a nissan tech.)
Old Jan 24, 2013 | 09:55 AM
jdm_phunk's Avatar
bump
Old Jan 24, 2013 | 10:08 AM
pityocamptes's Avatar
Valve cover gasket? Maybe blow by, but no leak, or slight leak into plug tubes?
Old Jan 24, 2013 | 10:14 AM
jdm_phunk's Avatar
commpression checks normal.
Replaced spark plugs/wires. No oil in plug tubes. No oil found externally of engine
Old Jan 24, 2013 | 10:31 AM
I've heard people complain about a smell and it ended up being the VCG, even though they had no leaks... just a thought...
Old Jan 24, 2013 | 10:35 AM
jdm_phunk's Avatar
well ill pull the VC tonight and check it out.
Old Dec 4, 2013 | 07:30 PM
x_40oz's Avatar
Did you ever find the solution to your problem? I have a 00 EM1 and having the same issue.
Old Feb 28, 2014 | 11:58 AM
zhizhi12's Avatar
2001 Honda crv, makes noise while driving, checked oil, added oil, then it started to smoke by oil stick
Delicieuxz
Apr 26, 2019 04:04 PM
Jeff Mizner
Dec 2, 2017 03:23 AM
s_chev
Dec 29, 2015 04:27 PM
tzych
May 15, 2007 07:16 PM
tyrone
Honda S2000
Oct 20, 2005 07:44 PM
