Obd 1 2 wire iacv fit obd2 manifold
I have searched everywhere past hour and got nothing. I am tired and frustrated. Anyways
I have a f20b (f2b) swap and it is obd2 running obd1 ecu and obd1 harness. I swapped out the upper plenum on the intake manifold not knowing it came off a 1998 prelude. Now my question is this
Can I put a 1994 obd1 , 2 wire iacv onto the 1998 obd2 upper plenum. If only 1 bolt lines up is fine with me.
Will a obd1 , 2 wire b series iacv work? I just need 1 bolt to line up so I can plug the damn thing
They use the same iacv so it should fit fine.
http://www.hondapartscheap.com/parts.../throttle-body
http://www.hondapartscheap.com/parts...hrottle-body-2
