96-2000 civic auto manual conversion Complete!!! f/s
I have for sale an almost complete auto to manual set up for a 96-00 civic
manual trans mount
manual trans tourque mount
t bracket
axels
flywheel with flywheel bolts
and clutch kit with pressure plate bolts
master cylinder with resivoir and bracket
clutch line
slave cylinder
clutch pedal
shift linkage
y8 style/zc intake manifold with 2 wire iacv
and auto engine harness converted to manual (re-pinned for 2 wire iacv)
obd2b p2e manual ecu
or manual obd1 p05 with obd2a-obd1 jumper harness
I have a 98 lx 5 speed trans as well but it needs work. has bearing noise and grinds 3rd and 4th
i am asking $300 for everything you need to do the conversion except the trans
$400 with the trans
i will even throw in an ex gauge cluster with tach if you buy everything including the trans I have two clusters one manual and one automatic that has the prndl blacked out and red needles
I will ship everything except the trans
hit me up and we can work out a deal
text me 2016873396
manual trans mount
t bracket
axels
clutch line
slave cylinder
clutch pedal
shift linkage
$400 with the trans
text me 2016873396
80 something views and not one offer
there is no one out there trying to do convert a 96-2000 civic from auto to manual?
sk8board{Pete}
Apr 9, 2013 05:16 AM
danwants2btheman
Sep 13, 2006 12:33 PM
