No start after sitting for 3-4 months
I thought my engine was blown again, so I let my car sit for about 3-4 months before I started the tear down. I started it up and thought the sound was from the top end, instead of my original thought which was rod knock. I pulled off the spark plug covers and saw that one of my spark plugs was not seated.
I tightened the spark plug back down and started it up. No problems, the sound was gone. It ran fine... for about 1 minute. Then all the sudden, it sputtered and died.
I'm thinking bad gas. I pulled the plugs and they smelled more like paint thinner than gas. Car just cranks and cranks. Gas level is just above the E. Also had a battery charger connected the whole time, not sure if that would be a problem.
Any ideas? I'm going to try some starter fluid in the TB when I get home tonight.
Well, since you said your gas smells paint thinner i'd say your problem would be, bad gas..lol.
Although I've had a car sit up for a year and a half with a quarter tank of 93 and it ran.
check your spark, make sure its good, also are you getting 3 clicks from the main relay?
I went ahead and got some starter fluid on my lunch break and no luck at all. I pulled the plugs and they were soaked in gas. I had my girlfriend turn over the engine while I checked for spark, nothing. No Spark. I checked for power at the distributor, 13.5V. The ECU reads no codes, no monitors set. I'm going to read up on "no spark" articles and see what I can check. I guess it's possible the distributor went bad after sitting for so long.
[QUOTE=fcm;48373447]Coil or ICM. 94[/QUOTE
Easiest way to isolate is borrow a distributor from someone. I just always have a spare one around cuz I'm not smart enough to test things properly like FCM lol
Fixed! :D So happy to have my car back again! It was the distributor or parts in it. I borrowed my friends dizzy and it fired right up.
Thanks for all the advice and help! Especially FCM, who's posts are always technically accurate and full of good troubleshooting procedures!
rewerbcrx
24
Mar 11, 2006 06:40 AM
STEV3-O
Jul 24, 2005 09:02 PM
Trbospnkr
Dec 29, 2003 09:46 AM
