h23a wont start
Old Jan 22, 2013 | 07:26 PM
acaliguy's Avatar
Icon2 h23a wont start
so ive finally completed my h23a vtec swap in my 02 accord so i tried to start it and all it does is crank i used the pcb ecu first and it wouldn't even run the fuel pump so then i swapped for f23 ecu(poa) and it made a little more of an attempt to start but still no life but this time you can hear the fuel pump and i have spark but i dont know if the injectors are even pulseing or if my spark plug wires are right also i plugged up my scan tool and it read both ecus just fine the poa threw a check engine where as the pcb did not does anyone know where to start with this problem?
Old Jan 22, 2013 | 08:10 PM
10thcb7's Avatar
Default Re: h23a wont start
What have you trouble shot your self?
When you did the swap did you follow some one else's DIY?
There might be some differences in sensors/locations and wiring.
Usually the ground that goes to the t-stat housing is the culprit but I don't know if you've checked that already. Let us know how it goes.
Old Jan 22, 2013 | 10:57 PM
hondaaccordf23's Avatar
what I did with the pcb ecu is switched the fuel pump wire from iirc a15 to a16
Posted from Honda-tech.com App for Android
Old Jan 24, 2013 | 01:00 AM
acaliguy's Avatar
Ok so ive looked at my firing order and im all good there now i had the wires on upside down causing the no start, so I tried the wire swap on the ecu and it starts and runs now on the pcb ecu now I have two issues still 1. my check engine is on and so I'm in limp mode now. The code is p1166 o2 sensor bank 2 sensor 1 heater malfunction something like that is there any way to get rid of this or do I have to live with it I'm obd2b pcb ecu etc
2. Temp gauge doesn't work at all
Any suggestions for these problems?
alex801to410
Oct 12, 2012 01:41 PM
bjfisher
Sep 2, 2008 08:14 PM
DelsoldS
Sep 13, 2005 02:03 PM
evoalf
Sep 4, 2004 06:21 AM
JBG's Ferio
Jul 31, 2003 09:14 AM
