idle adj on h22a4
Old Oct 20, 2002 | 06:17 PM
leptolude's Avatar
Default idle adj on h22a4
Hi Guys,
Is there any way to adjust the idle on an h22a4? i just installed ES motor mounts (which i like alot) but id like to up the idle to 975rpm to compensate for the vibration at 760. ive searched and found somthing about a screw on the throttle body, but that was for civis.... thanks for any help.
tia
-b
Old Oct 20, 2002 | 06:45 PM
DirtyLude's Avatar
Default Re: idle adj on h22a4 (leptolude)
Recessed flat headed screw on the throttle body above the intake opening.
Old Oct 21, 2002 | 05:16 AM
leptolude's Avatar
Default Re: idle adj on h22a4 (DirtyLude)
thanks mark,
is the ecu going to play around with the idle if i set it higher, or is the
"warmed-up-temp-idle-speed" a purely mechanical thing? ive got a ghetto-switch- on-the-ecu-memory-power-mod done, maybe that will keap it from self adjusting in the long term? the more work i do on this car, the more full engine managment makes sense. MO MONEY.....
thank again, how did the draging in london go?
-brett
Old Oct 21, 2002 | 06:47 AM
DirtyLude's Avatar
I've never tried to set stock idle that high. I don't think you should have too much problem with it, but I don't know. It's not like you're going to break anything.
I didn't go to St. Thomas. I'm in the middle of trying to build a new manifold. I'm not really into drag racing, but I still would have liked to go up there and hang out. Unfortunately; married + children does not equal free time.
Old Oct 23, 2002 | 05:41 PM
leptolude's Avatar
thanks for the reply
ive been playng with my idle speed for a few days now and it seems that Mr. ECU doesnt like a setting above 820rpm, it starts fluctuating up to 1300 or so... vroomm vrooom. im geussing that its a sensor conflict of some sorts... temp, or maybe adjusting the idle screw so much plays havoc with the feuling at idle... hmmm maybe i should see what i can do with the v-afc around idle. what do you think?
Old Oct 24, 2002 | 07:09 AM
tburyboost's Avatar
Hey, does anybody know about ordering a Spoon H22 motor? I can't find anybody that's got any info on them. Last year, you could order one and now I can't find them anywhere! Money isn't a big deal, I want a properly built Crane motor. Help if you can! Thanks.
thewrai6th
Oct 28, 2018 05:32 PM
Crxdriver1989
Dec 19, 2017 01:28 AM
CHANCELLOR12
Feb 6, 2016 03:46 AM
NAmodified
Dec 5, 2007 04:04 PM
