stroker theories?
Old Oct 20, 2002 | 06:13 PM
dfoxengr's Avatar
Default stroker theories?
could you theoretically take a b16, resleeve and bore to 86mm, then use an LS crank, aftermarket pistons, and LS rods, with a b16 head on it, and it all work.? may be dumb, but im curious. lemme know what u think. (at least can someone flame me if im totally out of line?)
[Modified by hybridvteceg, 5:28 PM 10/21/2002]
Old Oct 20, 2002 | 07:21 PM
dfoxengr's Avatar
Default Re: stroker theories? (hybridvteceg)
ideas, i kjnow you all have some, would this be like making your own custom stroker kit, or is it more involved than i think?
Old Oct 20, 2002 | 07:48 PM
dfoxengr's Avatar
before bedtime...lol
Old Oct 21, 2002 | 03:04 AM
dfoxengr's Avatar
anyone know
Old Oct 21, 2002 | 01:03 PM
dfoxengr's Avatar
gotta know?
Old Oct 21, 2002 | 01:27 PM
sgT's Avatar
sgT
You would have to increase the deck height to make those parts work right.
Otherwise you will need custom rods and pistons and suffer from incredibly bad
internal geometry
Old Oct 21, 2002 | 01:30 PM
dfoxengr's Avatar
Default Re: stroker theories? (sgT)
ahh thank you someone.. how do you increase deck height
Old Oct 21, 2002 | 01:49 PM
GB's Avatar
GB
You could use a machined spacer that is sandwiched between the block and the head. Some domestics people have been doing it for a while. The *only* benefit of this is if you lived in a smog-**** place like Cali and you wanted something that BAR workers probably wouldn't catch - they'd just go, "Ok, a b16a, everything checks fine." If this isn't essential, then it is cheaper, more reliable and stronger to buy a cheap LS bare block and use the same buildup techniques. That's why nobody (as far as we know) has done it.
Old Oct 21, 2002 | 03:59 PM
havalilsi's Avatar
Default Re: stroker theories? (GB)
some company down in san diego had a spacer on a b18 to make 2.? so to be able to get the correct rod stroke ratio. it was in sports compact car magazine. mucho dinero
Old Oct 21, 2002 | 07:01 PM
dfoxengr's Avatar
Default Re: stroker theories? (havalilsi)
huh, intereesting, i was just curious, my theory u know, lol
adam00
Feb 12, 2009 04:57 PM
NACvicSi
Apr 22, 2007 06:02 PM
CO_CReX
Apr 26, 2006 11:03 PM
andrewbolton
13
Apr 2, 2005 01:12 AM
94tegra
Jan 26, 2004 12:16 PM
