D16Y8 / D16A6 problems, Please help?!?!?
Old Jan 22, 2013 | 02:51 PM
efhatch1991's Avatar
Default D16Y8 / D16A6 problems, Please help?!?!?
so a week ago my car was dumping coolant into overflow tank( expanding it until fluid leaks out) and i replaced head gasket over this 3 day weekend and it seemed fine for a day until today wen it started doing that again and my heater going from burning hot too cool.... so im like whats going on. thermostat maybe? i have never replaced it before.... also my car surges idle. any advise is greatly appreciated
Old Jan 22, 2013 | 02:53 PM
Default Re: D16Y8 / D16A6 problems, Please help?!?!?
by the way i did headgasket saturday 1-19-13 and i had my head checked and milled / resurfaced too
Old Jan 22, 2013 | 02:54 PM
o and a brand new ARP stud kit was used. torqued to 60 ft pounds and in the right order
Old Jan 22, 2013 | 03:07 PM
24TEN's Avatar
PHANTOM MENACE
Maybe your block is warped?
Old Jan 22, 2013 | 03:39 PM
would a bad thermostat cause this too happen??? or am i wrong?
Old Jan 22, 2013 | 05:05 PM
bump....
Old Jan 22, 2013 | 05:07 PM
89 SI zero's Avatar
you should check your block, my a6 recently over heated and the head is currently off. i plan on taking the block out and getting it checked out and maybe resurfaced. but i was wondering if any of you honda diy wizards know where i could get a headgasket to help compromise for the shaved metal off both the block and head...because wouldnt that increase the compression ratio?? any info will help
Old Jan 22, 2013 | 05:23 PM
i have never over heated it past 3\4 on temp gauge... idk about previous owner but ya... my car ran perfect b4 i took head off but just sent coolant too overflow tank.. i have never replaced or checked thermostat,,, could that cause that???
Old Jan 22, 2013 | 05:54 PM
will thermostat cause this?????? or not?
Old Jan 24, 2013 | 04:10 PM
89 SI zero's Avatar
yeah, the thermostat can be it. it might not be opening once the operating temp is reached.
Old Jan 24, 2013 | 04:36 PM
luise808's Avatar
You can check to see if the T-stat is working by letting the car warm up and check to see if both hoses are hot. This would mean the t-stat is opening. They are not that expensive. I would just replace anyways.
Old Jan 28, 2013 | 05:10 AM
it was head gasket. i just re did it.... good too go.. now my car still surges for an idles too.. any ideas why??? my car came with a aftermarket 68mm throtle body.. maybe i should have tps adjusted differently from stock or what???
Old Jan 28, 2013 | 05:14 AM
facciol93's Avatar
what does "my car still surges for an idles too" mean?
what rpm does it idle at?
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
panda_eh2
Dec 27, 2007 11:32 PM
slickrickauto
Sep 6, 2007 03:41 PM
omgwtfhaxnub
Mar 20, 2005 03:29 PM
