Rough idle at cold start
Old Jan 21, 2013 | 06:04 PM
HOMEMADEPOWER's Avatar
Default Rough idle at cold start
I have a 97 Ls motor in my 99 hatchback.When the engine is cold the idle is rough for a couple seconds then it starts idling at normal rpm this has been going on for a few weeks.Car still runs great it idles normal when engine is warm.I cleaned the IACV,TPS and changed fuel filter and the problem is still ongoing.Any suggestion would be great.
Old Jan 21, 2013 | 06:11 PM
Former User's Avatar
Default Re: Rough idle at cold start
CEL codes?
Does the engine have an FITV?
Old Jan 21, 2013 | 06:15 PM
Originally Posted by RonJ@HT
CEL codes?
No CEL.Whats FITV?
Old Jan 21, 2013 | 06:17 PM
Click the link in my signature.
For engines that have one, the FITV maintains a high idle speed when the engine is cold.
Old Jan 21, 2013 | 08:28 PM
No I don't have a FITV.
Old Jan 22, 2013 | 01:31 AM
eghatch9295's Avatar
Stancetard Hate Monger
unless you have an aftermarket i/m, you have a fitv. check coolant level, your symptoms describe a problematic one perfectly
Old Jan 22, 2013 | 09:18 PM
I have a stock intake manifold. FITV is for 96 and below motors. Mine is a 97
Old Jan 22, 2013 | 09:25 PM
Does the CEL work?
Have you tried bleeding the cooling system?
Old Jan 23, 2013 | 07:50 PM
Does the CEL work?
Yes CEL does work. Cooling system been bleed correctly. Immature try and clean IACV again.
Nic0807
Honda Civic (2001 - 2005)
Dec 4, 2018 08:50 AM
NovaKnowledgeNow
Apr 21, 2015 02:25 AM
KimvdLinde
Jun 29, 2013 01:40 PM
EK45VTi
Dec 11, 2007 06:46 PM
typeeg
Jul 4, 2004 02:37 PM
