91 CRX will not start
Old Jan 21, 2013 | 03:45 PM
CRX Owner 465's Avatar
Default 91 CRX will not start
My 91 crx will turn over, but not start. It has a spark and the fuel pressure read 42 psi. Changed the fuel filter but it didn't help. I left my lights on and had to get a jump right before this happened. I'm not sure if that would have anything to do with it.
Old Jan 21, 2013 | 03:53 PM
Former User's Avatar
Default Re: 91 CRX will not start
Is spark bright white?
Have you checked the mechanical timing?
Do the injectors spray fuel?
CEL codes?
Old Jan 21, 2013 | 04:01 PM
No CEL with the key on
Bright white spark
timing is good
Not sure on the injectors. how would I check?
Old Jan 21, 2013 | 04:05 PM
stichedskater's Avatar
remove return line if gas comes out your getting fuel
edit:: 2 person job, one person watches the fuel return then the other turns to on position do not crank the motor
Old Jan 21, 2013 | 04:06 PM
MPFI?
Old Jan 21, 2013 | 04:24 PM
I've got fuel pressure, spark, and the timing hasn't jumped. The engine ran great before I turned the key off. Now it isn't hitting a lick. The fuel injectors aren't working. What would cause the fuel injectors not to spray?
Old Jan 21, 2013 | 04:26 PM
MPFI or DPFI?
Spray starting fluid into the TB to see if it starts.
Old Jan 21, 2013 | 04:33 PM
I'm not sure how to tell to be honest. I can see all four injectors lined up. Its got a 95 block, a 95 head, and a 95 computer. it says vtec on my valve cover. I'm not sure if that can tell you anything.
Old Jan 21, 2013 | 04:35 PM
so your running obd-1 conversion?
Old Jan 21, 2013 | 04:36 PM
Yes.
Old Jan 21, 2013 | 04:38 PM
did you check the fuel?
Old Jan 21, 2013 | 04:43 PM
Yes. The injectors aren't working. What would cause the injectors from spraying?
Old Jan 21, 2013 | 04:45 PM
clogged would be my first guess try different injectors make sure they are obd-1
also might be malfunctioning fuel relay...
Old Jan 21, 2013 | 04:47 PM
Thanks and it is DPFI.
Old Jan 21, 2013 | 04:54 PM
oh ok well did you do the dpfi->mpfi conversion first...
Old Jan 21, 2013 | 05:33 PM
Yes. It was converted to MPFI. I just got the car a few months ago and was trying to remember what all he had done to it. But yes, it does have that conversion.
Old Jan 21, 2013 | 05:35 PM
I just found where I had written everything down. Do you think it might be the ECU? I guess I should check with the wiring.
Old Jan 21, 2013 | 05:48 PM
Old Jan 21, 2013 | 05:49 PM
If the engine starts and runs briefly with starting fluid, then check whether all 4 injector clips get battery voltage with the key in ON(II).
Old Jan 21, 2013 | 06:27 PM
Okay. Thanks. I'll check that tomorrow and report back.
Old Jan 22, 2013 | 01:22 AM
chemik's Avatar
put the specifics of the swap so we can help better.
what obd1 harness did you use?
distributor?
obd1 injectors? or obd0 injectors?
resistor box used?
resistor box/injector compatibility perhaps?
anterman
Honda Civic (2001 - 2005)
Apr 12, 2016 05:33 AM
Schayward420
Oct 25, 2009 06:19 PM
91da_teg
Jan 21, 2009 11:16 PM
tRex99
11
Oct 27, 2004 06:01 PM
