PLEASE HELP MY 95 ACCORD WILL NOT START A FUEL PROBLEM
ok guys im new here but i have had it im out of my league here here is the story i have a 1995 Honda accord it all started when i ran it out of gas on the freeway so i put a couple gallons in it and went straight to the gas station ran fine all the way there i put about 5 gallons in i drove off and drove about half mile and it started to heistate real bad all through the rpm range while driving and everytime i stoped it idled rough so i took it home parked it.so far i have put a new fuel filter,fuel pump/strainer,main relay,the fuel pump fuse is good , I drained and cleaned the tank out put new gas in it,cleaned the injectors and a complete tune up.ever since i parked it it has not ran when i turn the key on i can not hear the pump run and there is no fuel getting to the fuel rail i pulled that bolt out and cranked it over nothing comes out plus the plugs are dry any ideas what else it can be im so pissed off right now any help would be greatly appreciated
If the fuel pump isn't working at all then it sounds you need a new fuel pump relay.
http://techauto.awardspace.com/ignition.html#flowchart
edbrowne2
Jul 28, 2017 06:18 AM
mastar91169
Jun 30, 2006 12:35 PM
trooper0641
24
Dec 12, 2004 10:09 PM
