D16 build question
Wondering what would be the best way to build my stock d16a6. I was thinking low compression pistons with a turbo set up, but wasn't too sure if that would be the right thing to do. Any advice?
comp test, leak down. If it isn't half in the grave save up for a turbo kit. Wen you have everything. Change your oil pump,water pump,timing belt, and do a tune up with ngk(1 strp colder) spark plugs, arp headstuds and put 150whp down. Just a starting point. Going for 80whp to 250whp is stupid. but the single will take that abuse
